I know you just want a review basically, but its a little on the expensive side, Id highly recommend going with secondskin, SDS, or murdermat.
OR if your looking to spend more for the best of the best, go with vibraflex.
That'd be silly.
Just buy SDS. You aren't going to beat that bang for your buck.
so is having 8 18s if you think about it, but people do it ;P
It is expensive, But i was able to get a great deal on some. The DD deadener is 3mm Thick, I know Vibraflex is 4mm but its also $150 for 22 sq ft.. I was able to get a hook up, thank God.
That'd be silly.
Terrible analogy however. 8 18's has more effectiveness at creating bass than 8 15's so there is a purpose. Vibraflex not so much.
That'd be silly.
Depending on your goals and how much you put on vibraflex can be more effective.
I was meaning its silly because of the excessiveness of it. Like have 10 locks on your front door, sure its better then one but most people consider that a bit silly.
Not sure why you negative rep'd but anyways it all depends on your point of view.
