Posted August 18, 201412 yr I am looking to build a 4th order or wall in a Tahoe at the c-pillar. I am looking at either 3 or 4 woofers. 1st question, has any one had success with a 4th order build with only 3 subs?2nd question will a 4th order with 4 subs or wall with 4 woofers work well at the c-pillar?
August 26, 201412 yr What equipment are you using?HUSubsSub ampsFront stage speakersFront stage ampProcessing etc...
August 26, 201412 yr Author Bandpass for better range of frequencies.HU pioneerSubs DC audio lvl 6 - 18's American bass 1100.1Mclaren 4-8's 2-super tweets on Taramps HD 2500Mclaren MLX-1000 crossover Edited August 26, 201412 yr by Bam bam
August 27, 201412 yr Bandpass for better range of frequencies. Try again. Does the opposite. Narrow range, in fact they are passed in a band. Any other reason?
August 27, 201412 yr Bandpass for better range of frequencies.Try again. Does the opposite. Narrow range, in fact they are passed in a band. Any other reason?4th orders have two narrow ranges. And if you build it right you can get a bigger range of frequencies. Regular ported boxes are a lot easier to design and get right.
September 22, 201411 yr Bandpass for better range of frequencies.Try again. Does the opposite. Narrow range, in fact they are passed in a band. Any other reason? 4th orders have two narrow ranges. And if you build it right you can get a bigger range of frequencies. Regular ported boxes are a lot easier to design and get right.And as I stated, it will NOT be a better range of frequencies. I understand BP frequency response, the OP obviously does not. It isn't about easier and getting it right, it is about being useful. Generally speaking that alignment offers no benefit and a ton of negatives. One thing good about 4th orders is yiu can get loud on low power if neededBP enclosures do not have an advantage over a normal ported enclosure in that way. Not unless you want a really narrow bandwidth, but that would be stupid.
