Posted September 16, 201411 yr I am currently working on a build in a 2000 chevy blazer. Everything has been going well up until now. I purchased a singer alt and decided to go ahead and purchase a mechman vcm. Everything has been hooked up to see if the alt was charging and its working fine. When I hooked up the vcm Im not getting any power to the unit. I went back to check the wires and to see if I was getting voltage from the ignition feed and everything is fine. I did notice however that the plug going to the alt only has one wire when its a four pronged plug. I wanted to know if that was the reason for things not working properly.
