Posted September 16, 201411 yr I wanted to know if anyone else has had this problem yet. Im working on a new build in a blazer everything is going well so far. Im just trying to get the last part of my electrical straight before I build the enclosure. I have a singer 350a alt and I decided to add a mechman vcm. Everything has been hooked up properly but Im not getting any power to the vcm. I checked over wires and made sure I was getting voltage and everything checks out fine. I happened to notice that the plug which hooks up to the alt has one red wire. The plug happens to have 4 prongs. I wanted to know if that could be the reason for things not working as they should.
