Posted November 1, 201410 yr I'm working on a box design for a single ported SA-12. I looked at the Sketchup design they have for a 1-12 ported, and I came up with this for my vehicle. It seems pretty dead on. Is the 13.5" x 2" port too narrow? The one in the Sketchup is 14" x 2" so I figure it's good. Thanks.
November 1, 201410 yr How much power you gonna be running? Should do just fine. I would add another baffle tho. Put a 1 in for # of extra baffles.
November 1, 201410 yr Author Soundqubed Q1-750 (so, ~750wattsish). I'll be adding baffle to the top of the box. Sub will be firing up with port back, if that matters at all also. But the 2" wide port is good? Is it necessary to put a 45 degree in every corner? I wsa going to do round over on edges of the port and put something in the corner of the port so the port has no 90 degree angles in it, but should I add anything tothe box coners itself?
November 1, 201410 yr 2" inch is fine man. 45s aren't necessarily important in your build. Won't make much of a difference since you're not going for deebeezz and need every tenth of a decimal. It will help with bracing though.
November 1, 201410 yr Author Cool deal man. Thanks for the help. I'll post some progres pics one I get started.
