February 24, 201511 yr I want to stay close within the $1200 range on subs probably about the same range with the amp..but I'm still making a list of thoseThats where I went wrong on myset was no budget...and I should of had one..
February 24, 201511 yr Author I have my budget for my electrical also so that's not a factorDo you have a good front stage?No yet..completely stock but I want to run two fosgate punch pro 6.5's in the front doors
February 24, 201511 yr I have my budget for my electrical also so that's not a factorDo you have a good front stage?No yet..completely stock but I want to run two fosgate punch pro 6.5's in the front doors Your going to need a good front stage to keep up with the subs. Are you going to add tweeters along with them?
February 24, 201511 yr Author I have my budget for my electrical also so that's not a factorDo you have a good front stage?No yet..completely stock but I want to run two fosgate punch pro 6.5's in the front doorsYour going to need a good front stage to keep up with the subs. Are you going to add tweeters along with them?Sure is
February 24, 201511 yr I have my budget for my electrical also so that's not a factorDo you have a good front stage?No yet..completely stock but I want to run two fosgate punch pro 6.5's in the front doorsYour going to need a good front stage to keep up with the subs. Are you going to add tweeters along with them?Sure is I take it as this is not your first build then.
