Posted July 1, 201510 yr I can pick these suckers up for 195 each locally, 12v and something like 1200cca ea, anyone every used these before? https://m.interstatebatteries.com/product/26-4163958589-4163958502-2147384763-4294492278-4251616327-4163992330-4163958586-4163958484-2147384903/8D-MHDConsidering two for my truck because the price is DUMB considering they're 130lb deep cycles. Edited July 2, 201510 yr by SpeakerBoy
July 7, 201510 yr I can pick these suckers up for 195 each locally, 12v and something like 1200cca ea, anyone every used these before?https://m.interstatebatteries.com/product/26-4163958589-4163958502-2147384763-4294492278-4251616327-4163992330-4163958586-4163958484-2147384903/8D-MHDConsidering two for my truck because the price is DUMB considering they're 130lb deep cycles.Link doesn't work for me.
July 7, 201510 yr Author Any reason I should avoid them?Are they agm batteries?I'm pretty sure the location I went to has agm and standard. Definitely following up, since I want to mount them sideways to save depth.
July 7, 201510 yr Author You're going to add 260lbs to your daily driver for what?Reserve until I can afford to move up to a lithium.
July 7, 201510 yr You're going to add 260lbs to your daily driver for what?Reserve until I can afford to move up to a lithium. I'm not saying don't do it, but consider the cost of the extra power from a bigger amp and all the extra weight. Is it really worth it in the end?
July 7, 201510 yr If you're serious just save for a HO alt, it'll cost more but it'll make everything easier. Edited July 7, 201510 yr by ssh
July 7, 201510 yr Author If you're serious just save for a HO alt, it'll cost more but it'll make everything easier.Found a 220a for my truck for around 350, and I only plan on about 3500rms total for the Near future. I don't have anything against starting the upgrades with the alt. Despite a decent price on one locally, I emailed singer this afternoon to see what he could cook up for me.
