September 4, 201510 yr Author Are there any HU's that pair up with the 360? I know my old set up d310+h701 I could control the processor through the HU. That would be preferred. if possible.
September 4, 201510 yr Won't pair up like that, but we couldn't tell if you were going to scrap the 360, use it, what settings you'd need, etc... I suppose my statement above isn't completely correct. The double din in my car would control it, but I run a full Windows PC in my car. Outside of that I don't think you'll find anything that will control it, but if you are using it for the processing it makes the double DIN search easier as you should look for a GUI you like and the functions you want.
September 4, 201510 yr Author second question to add to this...Anyone have any idea why my HU magically stopped working? If i turn the volume all the way up i can hear music, but its faint and scratchy. Everything was working great for 2-3 days (other than the fact i cant seem to link up to the 360 via bluetooth on my laptop) Only thing i have found is that the HU might not be "seeing" the aftermarket setup and therefore muting its inputs. Is there a way to trick the system into turning back on?
September 4, 201510 yr So it used to work with the 360? Then you should be able to get it working again. Most likely a loose wire or connection.
September 5, 201510 yr Been back and forth through the wiring and cant seem to find anything It's possible there could be a small break in the wire, or a loose connection on the 360's board.J
September 6, 201510 yr I'd isolate it and check the leads independent. ie, check the source from the h/u and then change the source to a phone or the like and see when/what it does.
September 7, 201510 yr Author might need to dumb that down for me lol but im open to whatever i need to do
September 7, 201510 yr Use a different source on the input of the 360. ie, your phone. See if that works.
September 7, 201510 yr Author Sorry,i thought i mentioned that. It does work that way. Aux using my phone, hooked up directly to the 360
September 8, 201510 yr Author FIXED IT!!!! had to adjust the properties on the program to admin and capatible with windows 8.
September 19, 201510 yr Author heading to louisville tomorrow to rewire the system as active and eliminate the xovers. From there ill be able to play with the 360...hopefully
September 23, 201510 yr Author The long and the short is, gains turned up too high, caused the engine noise and floor noise. rewiring the POS 3 different ways. ended up using the crossovers and the 360. not able to use the 360 to set my cross's but still sounds good
September 23, 201510 yr ended up using the crossovers and the 360. not able to use the 360 to set my cross's but still sounds goodHow could you use the crossovers if you couldn't set them??
