June 8, 200619 yr Wheels are a great design, look ghey as hell on that though. chit, you'd need a 20" rotor and 8 piston caliper just to stop the rolling mass of the wheels and tires. I bet he added a good 200+ pounds with those.<{POST_SNAPBACK}>Those would be some sick brakes
June 8, 200619 yr would take some stickey assed rubber to use them them to their full potential on anything other than 28"...lolwhat is it, for every 1lb of rotating mass at the far end of the raduis of a 28" diameter wheel (tire included ) is equal to the brakeing and acceleration decreases from adding 50lbs to the vehicle?something about a 1:50 ratio on the average sized wheel.
June 8, 200619 yr would take some stickey assed rubber to use them them to their full potential on anything other than 28"...lolwhat is it, for every 1lb of rotating mass at the far end of the raduis of a 28" diameter wheel (tire included ) is equal to the brakeing and acceleration decreases from adding 50lbs to the vehicle?something about a 1:50 ratio on the average sized wheel.tire included puts that wheel and tire combo at about 33"what does that equal? just about barely adequate braking, but i wouldn't want to have to execute a panic stop in that thing...wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
June 8, 200619 yr I don't think I could make it in AZit's way better than this humidity chit you guys have got here in FL and those rims = teh uber ghey
