If i wired two sundown SAZ 1500D and strappem to 3.0K watts RMS @ 2 ohm
and run two 15" mags, can i make it so the subs are only getting 2.2-2.4K watts? would that be just turning the gain down right? cus i wana run two amps but not power the subs at 3K more like 1.2 a peice.
I hear this will be loud and clean and make people go HUH!
Setup
IVA-w20
H701
Ipod 60gig
(1)(sub amp)
SAZ-1500D
(1)(sub)
SI Mag D2 15"
(1)(front amp)
SAX-100.2
(1)(front)
Crystal Mobile Sound SSCS-6
(1)(elect)
2150 Ody:D
(1)(elect)
1200 Ody
Big 3, with single 1/0, and single 1/0 for power and ground, stock alt for now.biggrin.gif
Upgrades in the future
In addition to above...:crazy:
(1)SAZ-1500D
(1)Si Mag D2 15"
(1)(dual front)Crystal Mobile Sound SSCS-6 (run the 100.2 at 2 ohm)
THIS is the setup im going with =P
You are correct sir, just keep your gains set to a resonable level and you'll be fine. BTW: It's a common misconception that our 15's take more power to be equally as loud, but it is the opposite. The 15's are just as loud with lower power compared to our 12's so you don't NEED more power on our 15's.
I think i might of miss lead you. I was going to run 1 and 1, 1 amp 1 sub, i just wana run 15"s cus of surface area. and there 15's and should get louder, cus im doing a single sub setup for now... i wanted to go with 15's
