Overkill mang.
You don't really need to make an IB installation feel bigger, but putting some acoustic sort of insulation to minimize reflections will be helpful. Mostly the area behind the speaker cone is what I'd worry about. Of course being captain overboard behind mine is 4 layers of Ensolite and a layer of acoustic foam. Open celled is better, but it will rot when it gets wet while a closed cell foam does less to dampen reflections it can't really mold as most are waterproof.
Two Words.
Over
Kill
secondskinaudio.com
I don't feel that my question was answered.
I want to know the effects of adding polyfil in my panels and door's.
Say I don't even use dynamat, and I stuff all of my panels, what effects will it have? Will i notice it? As much as adding dynamat? I don't care about rattles, I'm trying to make the interior more quiet and sound.
It will alter the path of some of the reflected waves a bit, which may clean up the response a little perhaps, but a foam will work better for doing that. Polyfill is not all that great as an acoustic damper so it won't really ake your rig that much quieter. The other generic use of polyfill is to make a space "feel" larger to a speaker but making something that is assumed infinetely large, larger isn't possible.
All i can tell you is there was a noticeable difference between just dampening and dampening + overkill (semiclosed neoprene foam).
a little more midbass and a little more clear. :)
Cant go wrong. Best stuff I've personally seen/used. But all i have to compare it to is dynamat.
But adding too much can reverse the effects, and make the enclosure seem smaller. :)
Good to know.
What is the optimal ratio? 1lb per cuft is what ive always heard. Less if you dont need it to "seem" as big and any more and you are just taking up space.
If your quieting road noise don't bother with polyfill. It won't help at all for killing road noise. Need something with mass to accomplish that. On the floors carpet jute works wonders for quieting road noise :)
Wheel wells too.
