Posted August 14, 200620 yr what are the ohm rateing on the new d2?thanksedit-->whats the diffrence between the d2 and the new bm? Edited August 14, 200620 yr by tyler krug
August 14, 200620 yr d2= dual 2ohm Mag.... and not a series of woofer.Their website lists the impedance as well.
August 14, 200620 yr Author d2= dual 2ohm Mag.... and not a series of woofer.Their website lists the impedance as well.<{POST_SNAPBACK}>so there is no diffrence between the bm and the other one? same thing?
August 14, 200620 yr The BMs are Basically a Mag, but will not handle the power a Mag will and are available ONLY in dual 4 ohm.
August 14, 200620 yr The BM's are our mid-line driver and, like Ryan said, are only available in dual 4 Ohm. The Mag's are dual 2 Ohm only.
August 14, 200620 yr Author The BM's are our mid-line driver and, like Ryan said, are only available in dual 4 Ohm. The Mag's are dual 2 Ohm only.<{POST_SNAPBACK}>thanks guys
