February 10, 20179 yr Author Digital music I've downloaded on my galaxy s5. It was downloaded at the highest bit rate available from Google play music . Transmitted via Bluetooth to the deck .
February 10, 20179 yr Author I finally figured out how to get into the eq , and put a -1 dip at 1.25k & 3.5k, then a -2 dip at 2k. Helped a ton.
February 10, 20179 yr 7 hours ago, Cwallaker said: Digital music I've downloaded on my galaxy s5. It was downloaded at the highest bit rate available from Google play music . Transmitted via Bluetooth to the deck . Ok. That could be your problem. Use a CD. The amount of GARBAGE on the internet EVEN at high bit rates is unbelievable. The quality difference can turn the best stereo in the world into garbage. That being said, a properly ripped CD at 192k+ is fine so it isn't like you need FLAC or 320k. Others that say differently haven't done a real blind A/B.
February 11, 20179 yr Author I figured it was part of the problem . The other is the fact that overexcursion has torn the surrounds on one of my mids .... I think one of my tweeters has failed as well . I ordered a pair of evil 6.5 . I got the 8 ohm version because I have such a large amp for my mids . I had originally planned to run at least a few drivers on it . The 8 ohm should drop the amps output to like 175 watts . So it looks lie I get to start over once my replacement diaphragm, and mids get here . I sure hope they can hang . These millies are mid bass monsters . I'm hoping to get the surround replaced ,If I can find somewhere to do it ??
