Hello all,
Quick question about wire gauges. I did some research and found Recommended Power and Ground Cable Size so think I should be okay, but wanted to check in with this community first.
Currently, I have 1/0 power cable running from the battery to the back of my truck. It hooks into a distro block and from that block I have two 4 gauge wire roughly ~2 feet or less connecting to two amps. One of them is 1000rms mono amp, and the other is a 100.2 amp for my front speakers.
If I upgrade the 1000rms amp to 1500rms, will the 4 gauge wire be able to handle the extra power since it is only a very short distance? The ground for the 1000rms amp is also ~2 feet of 4 gauge, will I need to upgrade that?
No, you shouldn't have a problem running 4ga unless your amplifier calls for 1/0. Do you know what the min size input is? If you have the extra cable it wouldn't hurt tho.
I am getting a sundown 1500D and the amp can take a 1/0 wire. I don't have any extra wires on hand and was hoping to keep the replacement install simple. Depending on how I orientate the new amp, I may be able to reduce the length of 4g wire to less than 1 ft from the distro block. If this is really not a good idea, then I can stop by my local shop and grab some extra wire.
4 ga wire should be sufficient for 1500w with that short of a run.  (1500*2)/12.8v=~234a
0-4ft 4ga should be sufficient for up to 250a. However, you could always upgrade the distro block to hold 2ga wire if you are really concerned about safety.
