Posted May 20, 20179 yr Hello all, I am wiring up two 1ohm DVC 12" subwoofers. I am putting both subwoofers in a sealed box, each of them has their own compartment and terminal. I am running a Sundown SAZ-1500D and want to wire it at 1ohm so I get ~750 to each sub. I want to double check to make sure the sub is wired correctly. I found the following diagram. Two 1ohm DVC Wiring Following the diagram, I ran one piece of wire from one positive to the negative on the other side of the sub. I then connect the terminal wires to the other neg/pos on the subs. I also do this for the other sub. Then from both terminals, I run their own wire to the Sundown which has space for two pos/neg inputs (it is internally bridged). Did I do this correctly? Edited May 20, 20179 yr by leon
