Posted October 18, 20188 yr Where can you find these I’ve seen someone mention they can handle 6v out Edited October 18, 20188 yr by Idonthalfohm Wrong post
October 19, 20188 yr 22 hours ago, Idonthalfohm said: I’ve seen someone mention they can handle 6v out Which would be HORRIBLY useless. As for where, not sure.
October 19, 20188 yr Author I meant like pre amp voltage my deck is 6v out I heard most Brazilians don’t like anything over 2.4
October 19, 20188 yr I know what you meant, still useless. No need for that much pre-amp voltage. Not going to get thermal noise with WAY less.
October 19, 20188 yr 16 hours ago, Idonthalfohm said: pre amp voltage my deck is 6v out Are you sure about this? What is it?
October 20, 20188 yr 5V is the MAX you're going to get and you'll probably never see that anyways. If you are truly concerned about it, and it's a proven fact one way or the other, then you need a different deck or amplifier(s).
