Posted January 30, 20197 yr Sweet new build by customer Cam T. in La Mes, California doing big things with this custom built ride full of Second Skin products. Thanks for insisting on high-quality American made sound deadening from Second Skin Audio we appreciate your continued use of our products throughout the years. Check out his awesome build log here: https://socalslc.com/table-of-contents/ Products: Damplifier Pro, Luxury Liner Pro, Heat Wave Pro, and Thermal Block #SoundDeadening #SecondSkinUSA #SecondSkinInsulation#SecondSkinAudio #DamplifierPro #LuxuryLinerPro #Spectrum#SpectrumLiquidSoundDeadening #AmericanMadeSoundDeadening #SecondSkinForTheWin #TeamSecondSkin
February 23, 20197 yr Very nice work on the install Sir. Just seems like your adding a lot of weight to a very specific designed aerodynamic vehicle.
February 25, 20197 yr Author On 2/22/2019 at 9:55 PM, Randal Johnson said: Very nice work on the install Sir. Just seems like your adding a lot of weight to a very specific designed aerodynamic vehicle. Cam has built this vehicle from the ground up, every aspect of this build has been thought out, planned out, and executed to his exact preferences. Adding sound deadening doesn't add as much weight as some would like you to believe when used properly in the correct locations and the correct layers. The weight is no different than adding a lightweight girlfriend/wife in the passenger seat. With an engine like he has, I doubt the weight will even be noticeable. His build log is on the first post, I am sure he would love to talk to you about why he did the things he did...he is a very smart and friendly man.
