Posted February 28, 20196 yr Does anyone know of a thiele-small parameter database or where I could go to get this info for a slightly older sub? In this case I have an original RE Audio SE 12 d2 that I am trying to build a box for but I cant find the needed info. I called the company and the lady said they don't have the info since they were discontinued. P.S. there have been two versions released since the one I have. Any help would be great.
February 28, 20196 yr I used t o have a few of those. Let me look and see if I can find the orange manual/specs...
February 28, 20196 yr I couldn't find the paper manual but I did find these on my laptop. Hope this helps! * Mounting Depth - 6.5” * Mounting Hole Diameter - 11” * Overall Diameter - 12.5” * Bolt Hole Circle - 11.75” * Motor Width - 6.25” * Motor Depth - 3.25” * Basket Depth - 3.25” * Displacement - 0.15 cu. ft. * Weight - 21 lbs. T/S Parameters: * Electrical Q Value -Qes: 0.49 * Mechanical Q Value -Qms: 4.5 * Total Speaker Q Value -Qts: 0.44 * Free Air Resonance -Fs: 25.1 Hz * Equivalent Compliance -Vas: 72.9 liters * One-Way, Linear Excursion -Xmax: 18 mm * Efficiency -SPL 1W/1m: 86.1 dB SPL * Effective Piston Area -Sd: 480 cm^2 * Force Factor -Bl: 17.7 * Thermal Power Handling -Pe: 600 W * Recommended Enclosures: * Sealed Compact: 0.75cf * Sealed Optimal: 1.0cf * Ported Compact: 1.5cf tuned @ 35Hz * Ported Optimal: 2.0cf tuned @ 33Hz
