Posted March 7, 20197 yr Admin Have you looked at the Incriminator Audio Death Row Series yet?! You are simply missing out if you haven't. With a 1500w RMS rating, the 3rd generation Death Row from Incriminator Audio. New for 2017, the DR has stepped the game up in the 1500 RMS subwoofer class. Building on the previous generation DR, this new model is the next step up in serious all-around performance. The all-new IA Death Row can work both ends of the spectrum, from the clean and composed daily driving sub with great clarity that can blend well with all kinds of music, to the mega output SPL installs with massive walls of subs. Firmly positioned smack in the middle of the Incriminator sub line up, the Death Row is the Swiss army knife of subs. As it is now an overbuilt design, there is no need to sweat hurting the Death Row. There has been improved cooling and a larger motor to all come together nicely for a stronger all around subwoofer. #AurhorizedDealer #IncriminatorAudio #ArriveLoud https://store.soundsolutionsaudio.com/subwoofers/incriminator-audio/death-row/ Features 8 Spoke Black Cast Basket 3" 4 Layer Flat Wound Aluminum Voice Coil Dual Black Progressive Spiders with Woven Tinsel Leads Injected Pulp Matrix Fiber Reinforced Cone Multi-Layer Foam Surround 8.26" 285 Oz Double Magnet Structure with Nickel Finish 688 Oz / 43 Pound Motor Structure 6mm Thick Aluminum Shorting Ring for Inductance Interlocking Aluminum Spider Spacer Assembly CILD² - Center Interlocking Dustcap ADC - Air Driven Cooling Nickel Plated Push Terminals Wrap Around Rubber Gasket 1500 Watt RMS Rated DVC 1 ohm or 2 ohm
