Posted March 10, 20196 yr Hello everyone, I am designing my own box and was hoping someone could review it. Goal was no smaller than 4 cu ft. Its an 18" Treo SSX rebuilt by PSI. Treo recommended 50cu in. of port, BUT i told them I was using aero ports and they still recommended the same..? I was always under the impression they didnt need as much port? This design is 1x 8" port = 50 cu in. I can't figure out another configuration to hit 40 cu in, if 50 is to much. Tuned to about 35hz. (see attached) Any help is appreciated Sketchup for box.skp
March 10, 20196 yr Seems fine assume these calculators are doing everything correctly. I'd consider a double baffle for the top. Designing and building enclosures should involve some trial and error so worse case you're out a sheet or two of mdf. Test the box in the vehicle before you do all the finishing touches (carpet or paint). Edited March 10, 20196 yr by lithium
March 12, 20196 yr Do you have specs on the driver? I get 5.86 cubes gross with a 33.12Hz tune with the 8" vent with either side flared. I can plot an anechoic environment and measure vent mach, but I need driver specs.
