i just put in my sundown 1500D and it turns on, but nothing comes out of it volts or anything :ughdunno:
Do you have the meter set to volts AC?
Sub preouts aren't turned off on the head unit?
Crossovers are set correctly?
No, its on DC volts
nope checked those too they were on
and i dont have any xovers on my HU, and i havnt even played with them on my amp, what do i need to have those set to?
No, its on DC volts
What comes out of your amplifier is not DC :)
I'd set the low pass filter to somewhere around 70-100Hz, the exact frequency will vary based on your install and listening tastes, but I try to fiddle with it until I can't hear where the sub is coming from.
oh ok lol
my LPF is set to 35 right now lol, ill play with it some
subsonic.. what should that be set to
and also my phase?
Edited by alex
oh ok lol
and also my phase?
That's another reason why you aren't getting much output :D
Subsonic...if you have a ported box, generally 5Hz below tuning is a good place. If your enclosure is tuned below 35Hz or so, you probably won't need it turned on at all. If you have a sealed enclosure, you definitely don't need it on.
Phase is one of those things that you can fiddle with, there's no absolute right answer. Try it for a while one way, reverse it and see if it sounds better/worse.
