Posted March 25, 200719 yr iam wondering what you guys think of the 10" Critical Mass LS102 sub. http://criticalmassaudio.com/catalog/index...amp;productId=2i can pick up 2 of these for $450. do yall think this would be a good deal? how to they sound? iam not looking to win and compatitions, just want some clean sounding bass.would appreaciate any info, good and bad?
March 25, 200719 yr The stuff from the ORIGINAL CM was great. I do however have a problem with them recommending a 52Hz tune in .75 cubes with that driver. WTF are they thinking?
March 26, 200719 yr Author well they will be sealed in .5cu ft each. so the 52Hz tuning shouldent matter right??
March 26, 200719 yr I'd tune to say 42.......i only say thins beacuse 42 seems to be the magical number in tuning freq.J
March 26, 200719 yr I'd tune to say 42.......i only say thins beacuse 42 seems to be the magical number in tuning freq.JYou're messing with us right? Seriously though. It's got a 3" coil, which has the added benefit of convection cooling on the outside, so I see no thermal problems arising. You'll definately hit its mechanical limits far before the thermal comes into play. YOu want good clean bass with some extension, tune right around the Fs, course if you're going sealed, it shouldn't matter atall. I'd definatelt use a slightly larger enclosure if you can though. That .75 will offer you better lowend and increased efficiency. I'm HIGHLY skeptical of the linear throw capability though. You will know when it's had too much.
