Posted March 30, 200718 yr If I wanted to divide my rectangular port right down the center for some extra bracing, will my port length have to stay the same or does it change since I technically have 2 seperate ports now???
March 30, 200718 yr instead of dividing it, why not brace it with some dowels, like every 8 inches with a 1" diameter dowel.
March 30, 200718 yr Since you will be making the port smaller without changing the length you will lower the tuning and have the possibility of port noise.
March 30, 200718 yr Author Since you will be making the port smaller without changing the length you will lower the tuning and have the possibility of port noise.ok, so i would have to calculate for 2 ports, correct?
March 30, 200718 yr I'll help you answer the question yourself. Do one 4"x2" port and two 2"x2" ports and see what you come up with.
