Posted April 30, 200718 yr well i got jacked for my system a while back. 1 week my HU, next week my amp, left the sub couldnt get it out or didn't want it. now i want to do my do an SQ system. The only thing i got are some 6.5" on the doors and a HU. i'm going to do it on my 01 Sierra reg. cab for the sub i wanna get a Fi Q 10 or 12 not sure yet.what does a SQ System consist of ? Edited April 30, 200718 yr by carguy6702
April 30, 200718 yr what does an SQ system consists of?A really good front stage and a substage that blends with it.Do you have pictures of your doors, and how the speakers are mounted?
April 30, 200718 yr Don't forget the SQ fairy dust. You can find a IASCA SQ cd to help tune the system. I know it was a learning tool for me.
April 30, 200718 yr Author the speakers are just on there replacing the factory ones nothing fancyi can get pics
April 30, 200718 yr Sq systems can be very simple (a set of good components (ran passively) and a sub with decent amplifiers), sound deadening is a must. A decent headunit with a 7 band eq is generally enough, especially one that has time alignment features. If not than your best bet is getting an eq.As for amps, headroom is the key for good sound with no distortion.As for speaker location, minimizing the path length difference will help with imaging.From there it can get expensive and complicated very easily. You can run a 30 band eq, with multiple sets of components, or you could do compression horns, electrostats, ribbon midranges etc... As for amps, thd isn't critical, you are looking for a company with a decent reputation, and overall good clean power. You don't need Audison amps and McIntosh decks, but they do have their plusses. SQ gets expensive very fast.
April 30, 200718 yr Author whats a front stage? i know they're speakers but is there anything else to it?
April 30, 200718 yr "Front stage" is a very ephemeral term for your soundstage and the equipment that produces it...basically, what and where you hear things. A competition CD like IASCA's tells you exactly where certain instruments are supposed to be, for example, if there's a cymbal on the left side of the stage in real life, it better be on the left side of your vehicle. Or if a singer's recorded dead center, your system would reproduce that realistically.
April 30, 200718 yr Front stage is the sound coming from in front of you (all of the speakers in front of you)... Since you are in a truck, all you should need is a good set of front components to achieve a desirable volume. Some kick panels will help with the path length difference, but a second set of tweets in the a-pillars might be necessary to raise the sound stage up to a desirable height.
April 30, 200718 yr Author so far what ill need is a good HU, good components+amp, for voicesub+amp, for basstweets on a pillar, more voiceand sound deadningi dont know about kick panels i use my e-brake alot maybe if i customize them???what about midbass subs and crossovers?
April 30, 200718 yr I wouldn't run a second set of tweets unless absolutely neccessary. what about midbass subs and crossovers?"Subs" imply sub-bass...midbass speakers reproduce midbass You don't *need* to do kickpanels, but it'd help to get a picture of your door so we could see what you're working with.
April 30, 200718 yr My advice would to see if you can find someone in your area with a quality sq setup. Then take a listen . Or go to a high end home stereo retailer and have a listen in the demo room .
April 30, 200718 yr no to double tweets. I have only heard 2 cars with double tweets, but both cars were horrible using this method. best thing to do is figure out speaker placement. start with the mids first in different positions and then try to find a good location for the tweets.
April 30, 200718 yr My advice would to see if you can find someone in your area with a quality sq setup. Then take a listen . Or go to a high end home stereo retailer and have a listen in the demo room . i agree. beware of spl competitors giving advice on sq systems lol
April 30, 200718 yr My advice would to see if you can find someone in your area with a quality sq setup. Then take a listen . Or go to a high end home stereo retailer and have a listen in the demo room . i agree. beware of spl competitors giving advice on sq systems lolDude, I competed in iasca for sq for the last two years, just doing spl as a change of scenery.I know in my buddies truck he runs two sets of tweeters, as long as they are on the same horizontal axis and attenuated lower they work great. My buddy is the husband of Kristen from team image dynamics.
May 1, 200718 yr So here are some pics of that friends SQ car:One of her team-matesMy car after being robbed of my first component set.MY first component set for competition, which sat in custom kick panels. Edited May 1, 200718 yr by audio-neon
May 1, 200718 yr hehe I've seen those doors and center before. Looks just like mine. I drive an 00 chevy standard cab.
May 1, 200718 yr Front stage is the sound coming from in front of you (all of the speakers in front of you)... Since you are in a truck, all you should need is a good set of front components to achieve a desirable volume. Some kick panels will help with the path length difference, but a second set of tweets in the a-pillars might be necessary to raise the sound stage up to a desirable height.The second set is a useless bandaid, in a few years the discussion of imaging tweeters and caps will be in the same sentence.
May 1, 200718 yr My advice would to see if you can find someone in your area with a quality sq setup. Then take a listen . Or go to a high end home stereo retailer and have a listen in the demo room . i agree. beware of spl competitors giving advice on sq systems lolDude, I competed in iasca for sq for the last two years, just doing spl as a change of scenery.I know in my buddies truck he runs two sets of tweeters, as long as they are on the same horizontal axis and attenuated lower they work great. My buddy is the husband of Kristen from team image dynamics.that wasn't directed at you
May 1, 200718 yr My advice would to see if you can find someone in your area with a quality sq setup. Then take a listen . Or go to a high end home stereo retailer and have a listen in the demo room . i agree. beware of spl competitors giving advice on sq systems lolDude, I competed in iasca for sq for the last two years, just doing spl as a change of scenery.I know in my buddies truck he runs two sets of tweeters, as long as they are on the same horizontal axis and attenuated lower they work great. My buddy is the husband of Kristen from team image dynamics.that wasn't directed at you exactly...carguy is a beginner at this sport, so i think that he should hear easier options than running 2 sets of tweets. it's your car carguy, but as ramos stated, find someone with a good setup and a ton of knowledge to help you out before you do anything. I have help from people such as Joe Black(Iasca and Meca sq world champion,Keith Turner(one of the best tuners in the nation),Jeff Smith(one of the best installers/tuners in the nation),Will Reinholtz(Iasca ultimate competitor and sq judge) and if they are not available, I always have ssa members such as Ramos and Dave Edwards that can offer advice. I trust all of these guys to help because they all believe in simple solutions. Contact Dave Edwards on this site. He has a killer 2 way setup and could probably offer you some good advice. Good luck with the project and take some progess pics once you start. Edited May 1, 200718 yr by ragnaroksq
May 1, 200718 yr Well , going by the pictures. If you run stock locations your gonna need a heaping helping of Time alignment on the mids . Don't know if you have dash locations , if you do they might be a good place to start with the tweets mounted . In my limited sq experience , there is no such thing as right or wrong. Only what works well in your installation in your vehicle. Be prepared to take some time just sitting in your vehicle listening , change aiming slightly, and more listening. Over and over until you are satisfied. Don't be afraid to try different things. Not every idea is a winner, but you never know until you try. I would also add , don't fall into the audiophool line of thinking that expensive always means it's better. You can do amazing things with what others consider crap if you take your time with it and do it right.
