Posted May 15, 200719 yr I have a 1966 Chevy C-10 Pickup and I am pulling the system out of my car to put in the Truck when I get the brakes fixed. Anyway, I have been surfing the web like crazy and I can't find a dash install kit for the truck So I can put my HU in it. Do they even make one? Or am I going to have to have someone cut into the dash to make a custom fitted one?
May 15, 200719 yr No sir , no kits available. Could always put the head unit i the glove box and keep the factory look of the dash.
May 16, 200719 yr Author well do they even make a wiring harness for an aftermarket HU or just an adapter to the stock radio.
May 16, 200719 yr For something that old, you are better off running new wires.As far as installing the HU, if you don't mind cutting the dash a little, you could weld something up to give the HU something to mount in.
May 19, 200718 yr Only way to get it in the dash is to cut. Either build a center console to mount the new unit in or deal with it being in the glove box if you don't want to cut. As far as wiring, you only need 3 wires. There are only like 6 behind the whole dash. You need power, ground and ignition switched power. Those shouldn't be that hard to come by on that truck. I know it wasn't on my '69.
May 19, 200718 yr there's also a housing you can buy that mounts a single din radio under the dashboard.
May 20, 200718 yr Thanksdisregard that last post i made, i didnt realize what thread i was in. that is completely unrelated...sorry lol
May 20, 200718 yr Its a square hole that you need, nothing special 7" x 2" iirc. You could easily build a console out of mdf, fit a front plate in your glovebox, or hack a small hole in the dash. Perhaps a small box connected under the dash would be okay as well (I don't remember what the dash layout looks like in those). There may be other good ideas too. Post some pics of your dash and more people will chime in.
May 20, 200718 yr Cut the dash. Or, mount in glove box or center console. To wire up, you'll need to run wires yourself.nG
May 24, 200718 yr Author Got pictures. Just waiting to get them back. in the mean time. What about mounting it into the ceiiling? Edited May 24, 200718 yr by Madrox
May 24, 200718 yr the underdash kit is junk. would not fit the contours of the dash at all. i see only three options...either airsaw the current factory location to accept a new single din unit (takes about 5 minutes), remove the liner from the glove box and mount there (did this once and retained enough area for a small pocket) or build a center console. we just finished up this last one in a truck with a pair of cupholders and 6x9's. nothing fancy, just some mdf and carpet.wiring is plain and simple like already mentioned.wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
May 25, 200718 yr build a center console. we just finished up this last one in a truck with a pair of cupholders and 6x9's. nothing fancy, just some mdf and carpet....you put speakers in the middle?
May 25, 200718 yr What you can't see is that behind the trim panel of that radio (which isn't stock) is the good old two-shaft style holes in the metal dash.
May 25, 200718 yr I know, I have had my share of older cars. Either way I'd still put it there. I thought at first you didn't want to cut the dash since it is a classic, but after seeing all the rust I'd definitely just whack a hole out and make the radio fit in there.
