I am getting a weird noise from my 12" BM, it sounds like the coil is rubbing or that its bottoming out. It is not on big time bass songs, only on like rock when a kick drum hits hard. I have it in a box I built to try and get it to 2cu ft and 34hz. I am using a Sundown Audio SAE-1000D to power it and have each voice coil hooked up to its own output on the amp. Any help is appreciated.
Well, you are severely overpowering the driver if in fact you are using the amp to its full potential, but give Nick a call at the contact number listed on the site. This may be a warranty issue.
Well, thats the amp that was recommended by Ben at Low-Hz. Also, its running at 2 ohms so it is only getting 600 watts according to the manual.
My apologies, I thought the SAE series had full power output at 2 ohms. You should be right within spec then. As for Low, eh, nevermind.
Whym, is Low-Hz not trustworthy? Also, if I am within spech what could be causing this problem?
I will say that the only time that you ever hear the noise is when you are right by the driver, you can't hear it while driving, but I just want to have a correctly working driver and make sure I won't damage it.
