Posted May 1, 200421 yr Ok....spill your latest stuff.....it may be too advanced for some of us...but I can use a good lesson every now and then on stuff....where you wanna start??? Edited May 1, 200421 yr by I8apony19
May 1, 200421 yr About cone / surround material:http://forums.caraudio.com/vb/showthread.php?t=57893I'm going to get reamed for it, but that's the way it is. It'll be interesting to see how it pans out.
May 1, 200421 yr Author I'm assuming (unless some other unknown variable) that a foam surround is more efficient than a rubber surround due to less mass? Edited May 1, 200421 yr by I8apony19
May 1, 200421 yr Author Perhaps due to the rubber absorbing more energy than the foam as well? ooo..didn't think about that...gonna have to agree with you on that idea
May 2, 200421 yr hmmmm. i know theres something hes not teling us. i can sence it hes working on new subs!
May 3, 200421 yr Interesting...... I have some theories, but will not share for I am of the uninformed variety... B)
May 3, 200421 yr Author Interesting...... I have some theories, but will not share for I am of the uninformed variety... B) Wuss...don't matter if you are right and wrong...just matters that you are learning....I'm not informed any more than you are
May 3, 200421 yr Interesting...... I have some theories, but will not share for I am of the uninformed variety... B)Wuss...don't matter if you are right and wrong...just matters that you are learning....I'm not informed any more than you are I choose to not make myself look a fool. Even though I am always correct. It's really disturbing to have a 176 IQ and stille be dumb. I cry every night.
May 5, 200421 yr Author Hey...don't leave us hangin' Nick....need some answers...and more talking...I want to llllllllllllllleeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaarrrrrrrrrrrnnnnnnnn.
May 5, 200421 yr If all things are kept the same, when you soften a suspension (make it more compliant) you lower Qes, Qts, and Fs, and you raise Vas. Very small changes, like a surround, can lower Qe's and raise Vas's enough to make a substantial difference. Making loudspeakers is tricky stuff.On the note of raising Qe's (opposite of above), think about it this way - if your motor is capable of a Qts of .30 and you have a TIGHT suspension, that suspension is going to fight that motor from doing its job - AKA raising Qe's into the .4's or so. Vas is raised because of a more compliant suspension, which also lowers Fs...as does adding mass. But adding mass reduces the overall efficiency. There, is that sufficient Clarke?
May 5, 200421 yr Author So a driver can compensate its low Qts by using a less compliant suspension..but would in turn lower overall efficiency of the driver....of course...more compliant suspensions would allow for more travel (eventual displacement)..if not tapped out by the motor or limited by it's basket...And no..not sufficient enough...feed me more!!!Now...if you use a very low Q driver, use very light materials which effectively raise your Fs, and use a tight suspension, wouldn't you yield a high Vas, and thus greatly increase the enclosure for a given alignment?..I'll get back to this in a second...Maximize efficiency = low inductance, low mms = higher Fs, varied Q depending on motor and complianceDisadvantages: Compensation of low end, larger box size required due to increased VasMaximize low end = average inductance, higher mms = lower Fs, varied Q depending on motor and complianceDisadvantages: Compensation of efficiency, shoebox wooferMaximize power handling = higher inductance, lower mms? = average Fs, assumed midline Q for a ported application??Disadvantages: Compensation of efficiency requires larger box size.?Now...a highly efficient, low Q driver will supply a larger Vas, and thus....a larger required box...Sounds like the Mag in comparison to the 12A to me...I assume it all starts at the Q of the motor itself...and can be manipulated by compliance...but would lower efficiency....Picking a motor's Q must be critical...But I assume this is where we factor in BL...as it has to effect the efficiency of the driver...Look what you've done to me...P.S. It's 2:25am...I HAVE an excuse if I'm wrong somewhere...plus..I know nothing... Edited May 5, 200421 yr by I8apony19
May 5, 200421 yr It's really disturbing to have a 176 IQ and stille be dumb. I cry every night. its even more disturbing that someone with an IQ of 176 couldnt spell the word "still" correctly
May 5, 200421 yr It's really disturbing to have a 176 IQ and stille be dumb. I cry every night.its even more disturbing that someone with an IQ of 176 couldnt spell the word "still" correctly Guess you missed the sarcasm in that.
May 6, 200421 yr Guess you missed the sarcasm in that. Sarcasm on the net must be blatant, otherwise you get people like hoss questioning you...
