Posted June 6, 200719 yr My uncle had all the tools to help with the build but then a lady drove into his garage and in the process ran over the main gas line. His whole garage was torched, including the tools and his brand new Honda Pilot. Since the last time I've posted, I haven't had time to build it but a coworker of mine wants to help out with the build so I just wanted to go over some options.TIAMy max outside dimensions: W=35" L=8.5" H=15". This is going in an '06 Suby wagon. The sealed box should work fine but I'm wondering if ported could work also. I listen to some rap, but mostly alternative and stuff like Blue October, Silversun Pickups, etc.I think I have the room for ported but I haven't a clue how to build the port. I'm thinking a slot port would be easier. From my readings, I think I'd want it tuned to 32hz but don't know what size to achieve a smooth punchy bass.Not sure if it'll help but I am running stock electrical, an Alpine 9815 deck, and a Hifonics ZX7500.2 pics for the same sealed box, yields 1.006 cu ft after displacement.
June 6, 200719 yr Author Is this in the wrong forum? My uncle had all the tools to help with the build but then a lady drove into his garage and in the process ran over the main gas line. His whole garage was torched, including the tools and his brand new Honda Pilot. Since the last time I've posted, I haven't had time to build it but a coworker of mine wants to help out with the build so I just wanted to go over some options.TIAMy max outside dimensions: W=35" L=8.5" H=15". This is going in an '06 Suby wagon. The sealed box should work fine but I'm wondering if ported could work also. I listen to some rap, but mostly alternative and stuff like Blue October, Silversun Pickups, etc.I think I have the room for ported but I haven't a clue how to build the port. I'm thinking a slot port would be easier. From my readings, I think I'd want it tuned to 32hz but don't know what size to achieve a smooth punchy bass.Not sure if it'll help but I am running stock electrical, an Alpine 9815 deck, and a Hifonics ZX7500.2 pics for the same sealed box, yields 1.006 cu ft after displacement. Edited June 6, 200719 yr by juicyfruit
June 7, 200719 yr A ported enclosure will be more efficient around the tuning frequency . But it will be a lot larger than your sealed enclosure you have modeled. A slot ported enclosure is pretty simple to build . What kind of room to you want to sacrifice to the audio gods ?
June 7, 200719 yr Author A ported enclosure will be more efficient around the tuning frequency . But it will be a lot larger than your sealed enclosure you have modeled. A slot ported enclosure is pretty simple to build . What kind of room to you want to sacrifice to the audio gods ? Sweet! So honored the all-knowing ramos is helping me out. From the bcae calculator:Height? = 15 InchesWidth? = 35 InchesDepth1? = 6.5 InchesDepth2? = 9.5 InchesIf the above dimensions are OUTSIDE dimensions, enter the thickness of the wood below.Wood Thickness = .75 InchesTotal box volume = 1.701 Ft3And from the SSD enclosure recommendations:Ported box we recommend using 1.8-2.5 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please)Looks like I'm a tad short on total volume. I could bump up the Depth1 and Depth2 numbers but would like to hear a noticeable change going from my sealed box in the pics to a ported. If I can't be louder and retain the tightness, I might stay sealed.Thanks much!
June 7, 200719 yr Easy now , I'm just me . Those that have met me will tell you there is no greatness, just me How much power is the hifonics gonna give the sub ( i'm not familiar with the new hifonics ) ?
June 7, 200719 yr Author Older Hifonics, rated at 750w RMS bridged but can't find any place to bench the mofo to see what it's really putting out. I suspect around 500?
June 7, 200719 yr Author As for 1.8-2.5 cubic feet, closer to 1.8 would yield tighter bass versus 2.5?
June 7, 200719 yr A ported enclosure will be more efficient around the tuning frequency . But it will be a lot larger than your sealed enclosure you have modeled. A slot ported enclosure is pretty simple to build . What kind of room to you want to sacrifice to the audio gods ? Sweet! So honored the all-knowing ramos is helping me out. From the bcae calculator:Height? = 15 InchesWidth? = 35 InchesDepth1? = 6.5 InchesDepth2? = 9.5 InchesIf the above dimensions are OUTSIDE dimensions, enter the thickness of the wood below.Wood Thickness = .75 InchesTotal box volume = 1.701 Ft3And from the SSD enclosure recommendations:Ported box we recommend using 1.8-2.5 cubic feet @ 33Hz (this is optimal in our eyes and to our ears, you can tune 31-35hz fine if you so please)Looks like I'm a tad short on total volume. I could bump up the Depth1 and Depth2 numbers but would like to hear a noticeable change going from my sealed box in the pics to a ported. If I can't be louder and retain the tightness, I might stay sealed.Thanks much!aggreeded ported will give you a better bass responce from the lower freq range
June 11, 200719 yr Author Using this calculator and using every bit of space I can in the trunk, I came up with this:Just wondering now where to buy this port or how to fabricate one and where to locate it. Should I have the sub facing up and the port facing the rear?Is it possible to make a slot port instead? Any suggestions welcome. Perhaps change the port length and diameter? Not sure how changing either affects the output so hopefully someone can help shed some light on this for me.TIA! Edited June 11, 200719 yr by juicyfruit
June 11, 200719 yr Ported enclosure will not give a better response at the lower frequencies... after tuning frequency the roll off is super steep.
June 11, 200719 yr Ported enclosure will not give a better response at the lower frequencies... after tuning frequency the roll off is super steep.Yeah man , I should have worded it better I would just stick to a sealed enclosure and try it out first. Easiest to build , you can always build another later down the road. Practice makes perfect
