Currently im brainstorming for an HT system for my apartment at college. Right now im leaning towards going with 3 zaph bargain mtm's for fronts, mach 5 15, and the rest i need opinions on.
First, id like a budget oriented reciever, but dont know what to look for really. Second, i was thinking i could just use a cheap bash/pe plate amp for the sub, but would like opinions? And lastly im not sure if i would need a pre-amp or any processing or anything else?
I would just like the reciever to play music off an ipod, with my xbox 360 on games and dvds, as that would be the only uses.
I like the yamaha recievers for budget, but it really depends on what $ amount constitutes budget to you.
Around 200 for the reciever is what i was thinking, but i have no real set budget.
If you're low on cash, consider a two channel set-up instead of cutting corners on a multi-channel set-up...
Indeed.
I'd rather have a good two channels than a mediocre five...
What about a refurbished reciever like this Onkyo TXSR504. I also agree with the 2 channel suggestion. Later when you have some spare loot you can always buy or build the surrounds.
Ya i guess i should have stated, im trying not drop alot on this to keep car audio my main focus. Im not really looking to spend the funds on a high end set up here.
I was going to do the three front zaph bargain MTMs first, then add the sub and rears later. But what do yall suggest if this is not the way to go.
I would say maybe 500 to 600 to start things off with the reciever and fronts . Maybe some suggestions on some floor standing towers at less than 200 per. Then ill add the sub or subs later on.
Zaph's plans should work for you.
Would it be better to do a 2.1 system with the zaph waveguide with the minimalist x-overs?
