Posted June 16, 200718 yr Level 210" 12" 15" Mounting Depth 5.5" 6" 7.5" Mounting Hole Diameter 9.25" 11" 14" Motor Width 6.5" 6.5" 6.5" Weight 18lbs 18.5lbs 19.5lbs VC Diameter 2.5" 2.5" 2.5" Magnet Weight 15lbs 15lbs 15lbs Power Handling RMS/Peak 300/600 300/600 300/600 Impedance D4ohm D 4ohm D 4ohm Sd 334.00 cm^2 519.00cm^2 872.00cm^2 Vas 36.40 L 73.90 L 145.10 L Cms 2.33e-04 m/N 1.96e-04 m/N 1.36e-04 m/N Mms 93.47 g 131.94g 168.60 g Fs 34.1 Hz 31.3 Hz 33.2 Hz Bl 20.89 N/A 20.89 N/A 20.89 N/A Re 7.20 ohm 7.20 ohm 7.20 ohm Qms 4.31 6.68 7.88 Qes 0.49 0.53 0.58 Xmax 18 mm 18 mm 18 mm Sensitivity 86.5 dB 88.2 dB 91.5 dB Edited June 16, 200718 yr by BigOso
June 16, 200718 yr Author Level 3 10" 12" 15" Mounting Depth 6.25" 6.75" 8" Mounting Hole Diameter 9.25" 11" 14" Motor Width 6.5" 6.5" 6.5" Weight 19.5lbs 20lbs 21lbs VC Diameter 3" 3" 3" Magnet Weight 17.5lbs 17.5lbs 17.5lbs Power Handling RMS/Peak 600/1200 600/1200 600/1200 Impedance D 4ohm or 2* D 4ohm or 2* D 4ohm or 2* Sd 487.00 cm^2 494.00 cm^2 791.00 cm^2 Vas 32.10 L 74.15 L 162.80 L Cms 9.67e-05 m/N 2.17e-04 m/N 1.86e-04 m/N Cas 2.29e-07 m^5/N 1.16e-06 m^5/N Mms 242.06 g 145.73 g 198.55 g Fs 32.9 Hz 28.3 Hz 26.2 Hz Bl 22.18 N/A 22.18 N/A 22.18 N/A Re 5.80 ohm 5.89 ohm 6.10 ohm Le 5.06 mH 5.06 mH 5.06 mH Qms 5.21 8.11 8.40 Qes 0.59 0.59 0.71 Qts 0.53 0.55 0.65 Xmax 22.5 mm 22.5 mm 22.5 mm Sensitivity 84.70 dB 86.40 dB 88.0 dB * There will be a $25 upgrade charge for high performance dual 2ohm coils.
June 16, 200718 yr Author Level 410" 12" 15" 18" Mounting Depth 6.25" 6.75" 8" 9" Mounting Hole Diameter 9.25" 11" 14" 16.75" Motor Width 7.75" 7.75" 7.75" 7.75" Weight 31.5lbs 32.5lbs 33lbs 35.5lbs VC Diameter 3" 3" 3" 3" Magnet Weight 28.5lbs 28.5lbs 28.5lbs 28.5lbs Power Handling RMS/Peak 1000/2000 1000/2000 1000/2000 1000/2000 Impedance D 2ohm D 2ohm D 2ohm D 2ohm Sd 314.00 cm^2 494.00 cm^2 791.00 cm^2 1159.00 cm^2 Vas 27.40 L 66.60 L 160.00 L 260.90 L Cms 1.99e-04 m/N 1.95e-04 m/N 1.83e-04 m/N 1.39e-04 m/N Mms 115.70 g 173.08 g 211.60 g 218.61 g Fs 33.2 Hz 27.4 Hz 25.6 Hz 28.9 Hz Bl 16.15 N/A 16.15 N/A 16.15 N/A 16.15 N/A Re 3.60 ohm 3.60 ohm 3.60 ohm 3.60 ohm Le 4.02 mH 4.02 mH 4.02 mH 4.02 mH Qms 5.15 5.13 6.07 6.55 Qes 0.43 0.42 0.47 0.70 Qts 0.40 0.39 0.44 0.63 Xmax 23.5 mm 23.5 mm 23.5 mm 23.5 mm Sensitivity 85.50 dB 87.0 dB 89.4 dB 91.4 dB Edited June 16, 200718 yr by BigOso
June 16, 200718 yr Author The subs are built in Sparks, NV. As for Box recommendations DC is currently wqorking on that. If you need any help with boxes for the subs give me a pm and I will help you to the best of my ability.
