Posted June 19, 200718 yr Im getting two Mach5 MAW-15's and I noticed that the qts was .32 I think. So I guess I will put them in a ported enclosure tuned to 32hz. Does that sound okay? How big should the box be for the two of them? around 6ft^3? Thanks~MadroX
June 19, 200718 yr Precisely... but that tuning frequency sounds good to me.Follow Mach5's box specifications, they are bang on.
June 19, 200718 yr Author I knew the QTS had nothing to do with the tuning of the box...... I just used that info to determine whether or not to put it in a ported enclosure.....
June 19, 200718 yr I knew the QTS had nothing to do with the tuning of the box...... I just used that info to determine whether or not to put it in a ported enclosure.....Actually, fs and Qes are what you are looking for. fs divided by Qes gives you efficiency bandwidth product (EBP). If EBP is greater than 50, then ported enclosure it is.
