Posted June 30, 200718 yr Where can I buy these Mach Audio MLI6.5? Not in the SSA store right only from the mach5audio.com website?I am also going to get some seas tweeter. I have an eclipse ea4000 so the woofers will be getting 75rms each and so will the tweeters. My headunit is a sony cd700 or whatever with graphic equalizer etc.... can I go active with it?Just with the headunit? This is my dumb idea. Cross everything over at 75hz and then play the woofers and mids, but obviously that isn't right?Anybody give me a hand or point me in the right direction if I'm doing this right?-Andres
June 30, 200718 yr to my knowledge, the mids are on their way to the ssa shop. weird thing is i have a similar setup planned : ea4000, mach5 6.5's and a pair of seas 27tffncwish i could tell you if you could use the crossovers on the amp. mine is in the mail i have no clue if you can use the hu for processing...i tried to google, but i didn't find any sony cd700 hu's.
June 30, 200718 yr to my knowledge, the mids are on their way to the ssa shop. weird thing is i have a similar setup planned : ea4000, mach5 6.5's and a pair of seas 27tffncwish i could tell you if you could use the crossovers on the amp. mine is in the mail i have no clue if you can use the hu for processing...i tried to google, but i didn't find any sony cd700 hu's.Yes the amp has processing, (high/low pass) enough for a basic active set-up. But even more fun with a capable head unit.
June 30, 200718 yr Won't be the most effective way, but bang for the buck it would be better than component sets you could buy for the same money.
