Posted July 6, 200718 yr im thinking about getting 2 maw-15's in my trunk the box will b 6 cu ft tuned to 30hz.. any clue on wat db's i'll hit with these installed running 600 watts at 2 ohms..
July 6, 200718 yr im thinking about getting 2 maw-15's in my trunk the box will b 6 cu ft tuned to 30hz.. any clue on wat db's i'll hit with these installed running 600 watts at 2 ohms..between 120 and 140 is my guess. WAY to many variables to give an accurate answer.
July 6, 200718 yr Author im thinking about getting 2 maw-15's in my trunk the box will b 6 cu ft tuned to 30hz.. any clue on wat db's i'll hit with these installed running 600 watts at 2 ohms..between 120 and 140 is my guess. WAY to many variables to give an accurate answer.thanks thats all i needed..
July 19, 200718 yr im thinking about getting 2 maw-15's in my trunk the box will b 6 cu ft tuned to 30hz.. any clue on wat db's i'll hit with these installed running 600 watts at 2 ohms..between 120 and 140 is my guess. WAY to many variables to give an accurate answer.thanks thats all i needed..135.5db is my guess
