Posted July 6, 200718 yr I'm really thinking of ordering up a couple of Level 4 subs for my cousins and I, but I am curious as to what you guys recommend as spec boxes as far as Volume/Port Area/Tuning? Thanks in advance!ALOHA FROM HAWAII,SKY
July 9, 200718 yr Depending on room i would say 5-8 tuned to around 33 for daily, port ares is kinda hard to say without knowing exactly what your working with
July 9, 200718 yr How much room would you really need for a pair of 10" level 4's seeing ~2100 watts each rms?... Could they work in 2 cubic feet ported to 46 hz... Or are these subs made for larger enclosures?
July 10, 200718 yr Author Depending on room i would say 5-8 tuned to around 33 for daily, port ares is kinda hard to say without knowing exactly what your working withSo the general rule for Level 4 subs daily is tuned to 33hz? 5-8ft^3 I would assume would be recommendations for LV 4 18"s, correct me if I'm wrong. I was more or less looking for box recommendations for each size(10", 12", 15", 18"). Does 12-16in^2 of port area per 1ft^3 sound about right? Thanks again for your time and help!ALOHA FROM HAWAII,SKY
