Posted April 4, 200818 yr Who would have ever thought IA could make an SQ woofer? Apparently the word on the street is we only make loud SPL drivers. Look again..Fs: 28.4 Hz Re: 3 Ohms seriesQms: 3.88Qes: .55Qts: .43Mms: 224gCms: 0.14mm/NSd: 480cm^2 Vas: 36.9Spl: 83.7dB 1W/1m Bl: 14.6 N/AXmax: 18mm Rms: 750W Bring on the haters!
April 4, 200818 yr Author And T/S too!! Yep!!!So Hick is fussing about pics already! Which he always does when I'm not prepared to show anything. So I grabbed some parts and took some pics to give you an idea and to shut him up.
April 4, 200818 yr Author Black chrome?Pricing and size ranges?Black Nickel finish - Standard 12's and 15's.
April 4, 200818 yr Looks like black nickel plating, which I like aesthetically. Uses ADC (right acronym? Air Driven Cooling?) which is an excellent concept. Clearly an underhung driver but probably with a fairly small coil judging by published Xmax and the height of the top plate in the picture.Any copper? Presumably single progressive spider? Maybe dual...hard to tell if it is progressive either from the picture.A little low on efficiency. Not a real concern, though, in my opinion.
April 4, 200818 yr Admin Looks good. But Nick, I thought you said flat cone, hence the name flatline.
April 4, 200818 yr Very sexy looking driver!!! Also I really like the look of the basket!! You really out did yourself this time Nick!!!!!
June 27, 200818 yr Overhung or underhung? Look like OH from the pics as it seems you can see coil between the top plate and the basket, but that thick of a top plate looks like an UH driver.
