September 23, 200521 yr Author Lots of cuts.Do you do every enclosure at your work or what....<{POST_SNAPBACK}>on the clock, hell ya...
September 23, 200521 yr i like the "build my enclosure on your dime" attitude!! i wish i could do that, but i'd have to get goverment permission to use power tools where i work. but it's looking good! what are the chambers tuned too? it looks like your middle chamber is going to be tuned extremely high...and what's the final tuning?wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
September 23, 200521 yr Author i got it all put together this morning (no glue) maybe later today i'll pull my seats out and see if it fits. if not i'll have to do the final build INSIDE the car i don't see any reason it shouldn't. i don't know what the chambers are tuned to. i had hexibase design it for me, and i trust he know his chit.it was designed for a near flat responce from 30-100Hz, w/ a nasty peak ~85Hz that the TL should love i think he said F3 was 23, so it'll still get crazy low too. i can't wait, all this talkin about it. the only thing stopping me is the LMT is coming to me next and i don't wanna loss all my room to play. i'll have pics later tonite..
September 24, 200521 yr Great design. Lovin the homemade sawhorses.<{POST_SNAPBACK}> get some help lifting that one into your car!
October 11, 200521 yr Author here is a lot more pics.....i still need to carpet it, and cut the "trim" pieces. and i still have to make a cover piece for the amps. i'm just gonna cut some wood and carpet it and flush mount the amps in an amp wall
October 12, 200521 yr Author you wouldn't even believe how good it sounds! the bass is just so clean and tight now! it will pound all the way to the high 20's up to...well i got it crossed over @ 100, but i'm sure it would go higher. i've never had a box w/ such a flat responce. every note is almost the same volume. its cool cause now it doesn't fade out as it gets higher. but on the down side i need to redo my front stage now, its starting to get drown out. i was thinking about getting an amp that does 200x2 @ 2ohm and running a pair of RE comps. but i had always hated bandpass becaus of the crappy reputation prefab boxes have. but this totaly changed my mind!
October 12, 200521 yr you wouldn't even believe how good it sounds! the bass is just so clean and tight now! it will pound all the way to the high 20's up to...well i got it crossed over @ 100, but i'm sure it would go higher. i've never had a box w/ such a flat responce. every note is almost the same volume. its cool cause now it doesn't fade out as it gets higher. but on the down side i need to redo my front stage now, its starting to get drown out. i was thinking about getting an amp that does 200x2 @ 2ohm and running a pair of RE comps. but i had always hated bandpass becaus of the crappy reputation prefab boxes have. but this totaly changed my mind!<{POST_SNAPBACK}>I'm telling you, just redo your gains with the 3:1 ratio. You'll thank me later.
October 22, 200520 yr nice i used to have a 88 excel 4 door w/ 2 pioneer 10's in a junky bandpass box (it was all free) that was pretty loud that must be sick
October 23, 200520 yr Author heres a little vid...http://www.realmofexcursion.com/videos/Sou...dbextreme.3.wmv
