bdawg8527
39 -
Posts posted by bdawg8527
my bad its only 22.5 in wide box dimensions are as follows
57in long 24in wide and 15in tall
all made with .75 mdf
and the port is in the front right under the box going back the length of the box. port dimesions are 4in by 22.5in
0 -
port is 4in by 23.5 in and it goes back id say like 40in lol. box is 57 in long
0 -
Ok, well i had no idea about tuning or anything when i made my first box. its 9.5 cubic ft with 90 in of port area, and i ran the port length till about the back of the box. ( pics soon). what i was wondering is can anyone provide me with the actual formula for calculating my port length. ( so i can just plug in hz volume and port area? ive got some calculators but like to see everything out. here is what im trying to accomplish by just cutting the box.
34 hz tuning
7.5 cubic ft
90in squared of port area
if i my box in a 01 grand am running from my trunk to my back seat, with the btl right in the back seat and the port under it. if i put the port in the trunk would it make it sound worse?
0 -
That looks awesome!
0 -
I just got hd tv so ive just been cruising the hd chanels recently
0 -
realized they were monsoon speakers, and had built in tweeters. so guess i have to get some tweeters also. thanks for the replys tho
0 -
OK, so im trying to put new 6.5's in my moms car for christmas. and her stock speakers (blown) had 2 sets of wires coming to them, they were 2 negative and 2 positive. to each speaker. and the speakers i bought have only 1 set.(1 positive and 1 negavitve). so how do i hook it up. just put both positive to the 1 on the spaker? or only use 1 set of wires?
0 -
Sounds like this system ur saving up to get is going ot be a beast...
yea bought everything i need now. cept a few small things, like i may need a install kit for my car for my head unit. it was a double din so i need an adapter thing. and then just some speaker wire and amp wire. got my 0 gauge in. sub comes in on friday(october 16th) and ill build box, then amp next week and ill start bumpin.
0 -
ok, made a newer design, cant post pics but its about 7 cubic feet. and its got about 110 square inches of port area. the port is accross the bottom and the sub area is above it.
0 -
ok, gonna be fun fitting this in my grand am. removed the double fold backseat. and plan on put a box running all the way from the trunk to behind the driver seat here are some plans for the box its about 9-10 cubic ft right now.
questions?
shape dosent matter dose it?
do u think ill need some more support?
how big should i make the port?
0 -
ok, buying my amp wiring kit. how big should my fuse be? ive got a 3000 watt sundown amp. and am going to use an isolator for my kinetik 2400 in the trunk?
0 -
I have a simple quick question. If i wire my new kinetik 2400 in parallel to my stock car battery will i be fine with my 3000 watt amp? some people are saying i must get an isolator and others not. and i have no idea if it will damage anything or not. and no i wont be playing music without the car on
0 -
if your not going to play your system with the car off then it wont really be needed (some use it when using two different batteries but you dont have to).
then how do i wire it? parallel? thought u had to have one with another battery
you dont have to have one... it helps when you have 2 diff batterys connected and you play ur system with ur car off it helps charge each other i think from what i have read.
you probably wont play ur system with ur car off since its for a daily driver, most daily drives drive and bump, from what i have seen atleast.
you got a nice set up goin for your self man your gonna be pounding like a champ!!!
get a volt meter also to help you monitor ur voltage.
what kind of Head unit u got?
Yea i cant wait, good to know on the isolator. and yea just need a good amp wire kit and a volt meter. i got a alpine cda-9886 headunit. not sure about how much wire ill need. like if i can wire my battery and amp with an amp kit.
0 -
0 -
what kind of wires do you need.. just 1/0 gauge? look in knukoncepts.com for amp kits
x2, any size up to 1/0awg use KnuKonceptz if you need 2/0awg or bigger then go get some welding wire at weldingsupply.com or weldingdepot.com
ok getting an amp wiring kit from there. and another question guys, running an isolator is fine right? seen mixed views about them and id hae to use one as i have a diff battery under the hood.
0 -
Ok, bought a kinetik 2400. now one of the last things i need is a amp wire kit. anyone have a good idea of what kit to buy? and about how much and what kind should i use on the battery.
0 -
think 1 2400 would cover? guess i could always add another if i have problems.
0 -
ok, bought the 3000d sundown amp. ill turn the gains down a little so its about 2500 watt's. but what battery should i get now? ive got a 200 amp HO alternator, and 1 fi btl 18. also do i put a big one under the hood. or keep my stock one and get a new battery in the back? and what size battery?
0 -
i got fully loaded, coiling option and everything and got the dual 2 version
0 -
i have a HO 200 amp alternator. dont have any extra batteries(just havent ordered). so u got the 3000d referbished? and use it on 1 fi btl loaded right? its what im thinking of doing. and reccomend a good battery?
i am running a Kinetik hc2400..were you going th purchase the "New Heatsink" B stock SAZ 3000d?
yea thats what i was going to get. and Jay-cee i got the Hixm Coil extra. im leaning between the 2 amps. kinda want the 3000d and turn the gains down a little and have room for later. but if i get the 2000d its new and has 2 year warranty.
0 -
yea man i got the 3000d and absolutly love it...yea i had to send it back in but totally wortth the wait...Db-r is excellent with customer service, free shipping from db-r to me which saved me forty bucks.. definitly recommend the Sundown..
If u go with the SAZ 2000d im pretty sure it does rated power at 12.6v which is amazing so if u have strong electrical then you will see more powwwerrr!!!
0 -
ok, i found some sundown amps. which one should i get?
http://www.db-r.com/sell/store2/index.php?main_page=product_info&cPath=65_67_69_83&products_id=210
or the one with older style heatsinks. they come with 1 year warranty so i should be good. just sucks on the wait time. i think the new style heatsinks. as it should perform better
0 -
how about this. if money dosent matter, hands down whats the best amp to power my fi btl 18?
honestly, i would really try and go for the sundown saz-2000D! i am running an 18" btl also and i have a sundown 2000D. i did alot of research on here befor i orderd and from everything i gatherd from all the guys on here SUNDOWN is a great company the amp is sweet looking i love it!
being your first setup this is what i call a big boy setup lol. So take your time on this build man, order the sundown 2000D honestly you will love it i have no doubt. if money is tight after you order ur sundown 2000d take ur time and order everything else as ur money comes be paitence it will pay off in the end!!
good idea getting ur HO alt you will need it, make sure you do the big 3 with it.
for a second battery go with like a kenetik 800 or higher or XS batteries or DEKA is pretty good from what i hear.
Knuconceptz wireing is great also and its not very expensive!
i saw that you said you will worry about ur front stage spekers later, that might be an issue if you want to get the WOW effect from the people listing to your system. if the song sounds like shit so will the bass enless ur playing a pure bass song or just some tones. i am sure this is going to be a daily driver so your gonna need a good front stage also. (go with a sundown 100.4 amp)
you will need to deaden your car for sure! thats were SECONDSKIN comes in look into them for sure!
if you have any questions at all theres alot of great guys on this site that can help you like they helped me!
where did u get ur amp? i saw a 3500 d from sundown from ebay for 800. money isnt really a matter. ill have a few hundred more every week. thing is i have to order everything online, using paypal.
0 -
0
Help With 18 BTL Box
in Fi Technical
i plan on cutting it at 42in and adding the back there. so itl go from 57 in to 42, which should make it 7.5 cubic ft. and the percice is 42.66 in, then making my port 20.14 in log should give me 34 hz right?
