fearlessgangsta
Members
    410
Everything posted by fearlessgangsta
  1. fearlessgangsta
    Switching old school to new school
    ^ Win But, have you looked into the Dcons, Incriminator I's, Skar IVX's, or Sundown E's? All rated at 300w and at 200w a piece should sound nice.
  2. fearlessgangsta
    Juice Box battery
    Oh, ok I only knew the dude had the bloated battery and wanted it warrantied didn't know the back story. Thanks for clearing that up.
  3. fearlessgangsta
    Juice Box battery
    I saw a guy that had a bloated Juicebox apple that he needed warranty on. I would try find that thread to see how Juicebox handled that situation.
  4. fearlessgangsta
    2 aq2200's or 2 Bc2000's....
    I had the same situation a guy didn't like my amp so I got my 2k back. Strap that 2200 and have some fun
  5. fearlessgangsta
    A Suburban A Warhorse and a Pair of SMDeez
    Looks interesting. I'm watching sir.
  6. fearlessgangsta
    Big 3 in 4/0 questions
    Ok, I was thinking about aluminum at work. I'm looking forward to your work sir. Function over cosmetics. Yeah copper is $$$. One day I have my $$$$ on point.lol
  7. So Shizzzon got my attention with some cheap 4/0 gauge he got. I'm thinking of adding a couple of 4/0 grounds and a couple 4/0 runs from alt to my front batts. I have never worked with the stuff before. I will be upgrading my alt to a 400 amp eventually so I'm trying to plan ahead. Since the length of these runs will be shorter than 6-7 feet will there be any benefit vs 0 gauge? Is there a way to fuse 4/0 wire? Also what lugs do you use for your 4/0 wire the only ones I found have a minimum buy amount of 10?
  8. fearlessgangsta
    Hair Trick
    Violent is the only word. One day I'll get to that level.
  9. fearlessgangsta
    I work part time so I have to save up. I don't need cosmetics I really just need the copper I could cut holes in it and grind it smooth on the edges.
  10. fearlessgangsta
    Happy Birthday Impious!
    HBD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  11. fearlessgangsta
    took the truck down to the local drag strip tonight.....
    What was it making 500-600hp?
  12. fearlessgangsta
    SSA welcomes Crescendo Audio to the forum and store.
    Welcome. Now I can ask questions on my favorite forum. Time for some Crescendo mids.
  13. fearlessgangsta
    Ok, I thought the alt runs were redundant, but I have seen it done. Now I will do the two runs to the 3400 and then run them back. That's why I asked about fusing lower when using multiple runs. I like to be as safe as possible especially when it could mess up my amp, speaker or my only transportation. Now Shizzz who do I need to see about some buss bars down the road?
  14. fearlessgangsta
    I'm working on getting a dual alt setup with a 400amp singer. So then I'm putting my stock charging back to stock, but leaving the grounds. All wire will be 4/0 So the reason I'm not putting the 3400 in the back is because I'm thinking of putting a couple of 3100's behind my box with buss bars. Now when I get the alt I'm going to have to upgrade my cable that's why I'm looking into it now. So I'm going to ground the alt to the frame and the 3400 to the same spot then run a ground from the 3400 back to the buss bar.. Now I'm consfused on how I'm going to do my power wires. I'm thinking of doing a run from the alt positive to my 3400 ( how would I fuse this one wire?). Then I'm going to do a run from the 3400 to the buss bars(now can I fusethinking one 350 since there will be 3 wires going to the back? Then thinking of doing 1 or 2 runs from the alt back to the buss bars(now should I fuse these around 350 or so because it's 2 runs?) So that's 1 wire from alt to front batt. Then 3 power runs to the back and a ground run to the back. Also a couple of more grounds to the frame in the back.
  15. fearlessgangsta
    That would throw someone of there game if there trying to tree you.lol
  16. fearlessgangsta
    Alright sir. I have two batts under the hood. 1 stock and a xs power 3400. I have a ground from my 3400 to the stock batt. Another ground from my stock batt through my electric ground clamp to the engine block. I also have a ground from my 3400 just going to the frame. Now from my alt positive post i have a run to the stock batt and a run to the 3400. Then from my 3400 I have a fused run back to the amp and a ground run back to the amp. I'm thinking of getting the 4/0 and grounding my 3400 to the engine block also, and running a positive from stock straight to the positive of the 3400. So when I'm done basicly my grounds will be connected at two points and the 3400 also has another ground. And the positives will be doubled because they will be connected at the alt and have a straight peice going from positive to positive. Alt is stock 160 will be upgrading. Wire is Knu 0 gauge Amp is/was crescendo 2k upgrading All fuses are 300amp Knu fuses.
  17. fearlessgangsta
    Car Audio Addiction "The Documentary"
    Interested for sure. Any certain time during summer?
  18. fearlessgangsta
    SPL Lab came in the mail, video with some numbers!
    Good numbers. I think it will really shine when you fix up the box.
  19. fearlessgangsta
    I believe it said the jacket could withstand temps of 125c. My 0gauge doesn't have tubing on it and it's been like that. It's all zip tied around the top of my engine bay.
  20. fearlessgangsta
    The stuff Shizz linked is automotive 4/0
  21. fearlessgangsta
    installed the audiocontrol epicenter
    How are you going to talk more ish and then say drop it? SMD status over here.
  22. fearlessgangsta
    lol was that your best shot at me? lol calling me fat ... lol you must be joking little boy. let see.. first off.. i call my self bigjon. ... second off.. i have been fat all my life, and most time the BEST fat jokes were told BY ME!... i have heard them all.. so i hope you dont think some how in your streange little world that calling ,me a fat fuck some how cuts me ... you must have it bad ............ and lastly... im more then sure your just mad because this fat fuck is the boyfriend of the girl you tried to PM and chat it up with...... you have another thing coming if you think your gonna have a chance at my chick... lol please son. next time you try to step to me or my chick you may wanna try a little harder. be a little smarter. Jon going in. Agree and can relate with the being big parts. People hate. If he really tried to get at your girl though that's another level of Ahole.
  23. fearlessgangsta
    Ignorance is bliss on SMD it in the air over there especially lately. Peace be with you!!!!!!!!!!!!!!!!!!!! ? I only go on there for lol's And to look at the tire and wheel section. SSA for life.
  24. fearlessgangsta
  25. fearlessgangsta
    GCONs are on the store.
    Yeahhhhhh Dawgggggg. But I may have to wait
