Hansk
Members-
257 -
Content Type
Profiles
Forums
Gallery
Everything posted by Hansk
nice job on the box....
welcome..... its a great forum
electrical problem
Hansk replied to Hansk's topic in Amplifiers / Head Units / Processors / Electrical
that was at idle but then today it went up to 14.1 idle then hovers around 12.4.12.9 when volume is turn up quite a bit and the lowest i saw it drop to today was 11.7 -
electrical problem
yup i did... i waited a couple more hours later and drove around again at idle is at 13.1 and when system is full tilt it drop ti like 12.2 a little tiny bit better but nothing i can do w/o a h/o alt sooo....... but thanks for they help guys always appreciate it -
Wiring Help?
Hansk replied to jordan00711's topic in Amplifiers / Head Units / Processors / Electrical
did you feel the subs to see if they are moving at all b/c that happened to me and i just had to turn up the volt setting more -
Wiring Help?
i have the same amp..... where did you set the level knob at...and how are the rest of your setting at?? -
electrical problem
well i found out what was wrong. the bolt that tightens the tensioner for the alt and power steering broke in half....got it fixed and im up in running..... the only thing is without having a h/o alt, the stinger volt meter reads my system full tilt at like 12.2 and drops to 11.9 ......... -
electrical problem
thats pretty much what i was thinking to ... im taking it to a shop tomorrow morning but i was just making sure it was nothing i did to cause the problem.. -
electrical problem
is there a possibility that these grounds could be bad? -
electrical problem
heres a pic of chassis ground here is another angle of chassis ground here a pick of stock ground i replaced -
electrical problem
well at work tonight i talked to a buddy of mine who is a mechanic and he told me some thing to look at and the belts are on.. they seem not to be moving as fast as normal and there is one pully on the bottom thats not moving at all while the belt around it is...... here ill try to upload another video that i have about the belts i know you really can see anything but ill try uploading it anyway -
electrical problem
do you think that would tie into the power steering though b/c it went out after i did the big 3 -
electrical problem
ok.. ill give it a try -
electrical problem
would you explain to me what happen to your buddies car?? -
electrical problem
just wanna make sure i did this big 3 right and im not the cause of my stuff not to work can someone please check me -
electrical problem
well come to find out when i got home from work bc i noticed all my light started dimming more and more and i thought to myself that the alt isnt charging the batts and the whole car is running off the two batts. i checked my voltage on both batt when i got home and the front batt is at 8.6 and the rear is at 7.5. with would explain my power steering out is bc the belts and pulley went out. the alt isnt kicking in to charge them.... urghhhh frustrasting -
i just ordered a stinger digital volt meter and my question is ... where would be the best place to wire it to? the starter batt, the amp, the radio? im just not sure. any help would be appreciated
electrical problem
not yet im at work ... i will when i get home. -
electrical problem
huh any other explanations? -
Hooking up two amps to one sub
Hansk replied to imhungnurnot's topic in Amplifiers / Head Units / Processors / Electrical
DD's can take a fair bit of abuse. ok well im not familair with those subs. Thats why i said that...but very interesting thread -
electrical problem
nobody else has any ideas??? -
electrical problem
I checked that too and nothing -
Like I said I could be wrong in my previous post but I wouldn't do it... -
dude im loving the cardboard..hahahahah ...i take it you liking those apline speakers........ nice work man.... sound good :popcorn: :drink40:
