377 -
Content Type
Profiles
Forums
Gallery
Everything posted by muddybass
personally id go with kinetik
john you should talk to meade and see how he handles his clipping problems, since he straps 4000 watts to each btl
with the right electrical the sundowns will push more then 3000
i think jl will output the infinitys in sq
just goto a automotive eleclectrical shop and ask for a load test
nick said scott has been really sick
take the wires out of the port, drill a hole in the back of the box and run the wires through and seal it off with glue..... then it will look a little more proffesional
i wonder if fi has the x still? that would be a cheap and loud woofer
Fi Q15... not much excursion, why? (videos and pics)
muddybass replied to themerc's topic in Fi Technical
and q's have 27mm of xmax -
aint gonna get much sound quality out of a ported box with bl's, go and search around ssa and fi
q's still rock your head and sound good in either sealed or ported, thats right john actully just from q recommendantions
had them in a sealed box though just didnt get loud enough, but the sq was great
goto a sound shop and get your head unit and amps o-scoped
Bp Power: just finished adding a new option for the SSD and Q series subs. This new option adds a machined aluminum compression plug to the pole which helps channel all of the air under the dustcap around the coil for better cooling. To aid with this increased airflow we also add 6 axial cooling channels in the top plate. Along with increased thermal capacity comes the addition of an extra spider and a changed spider pack for a little extra mechanical ability. All of these new features increase power handling from 200-500 Watts depending on the application. Its just another way of tuning and tailoring your subs to your exact needs. Review: http://www.soundsolutionsaudio.com/forum/i...?showtopic=7135
like brian said the btl will handle that power nicer, pushing 2400 to a bl is a little pushy
The BL line is pretty much a lower power alternative to a BTL or a higher power alternative to the Q series of woofers. This is more of a street jamming type woofer that
what he said above and also if you bought subs from them shoulda got small decals, if u want bigger goto a sticker shop
i dont believe you because i have two type-r's sitting in my room collecting dust because they are chitty speakers
the q's have a good review, i run 2 out a ported box tuned to 32hz, but ive heard q's in sealed they still get really low and the sq is amazing
Doing an install for a friend, opinions on the Memphis 4000 watt mono
muddybass replied to Brian10962001's topic in General Audio
why use optima's as they are not deisnged for car audio only for those extra cranking amps, if you were to put in a second battery id go with kinetik -
those type-r's having trouble picking up them lows? as it sounds like it...
sounds like clipping to me
the q will be a great sub for you, now sealed itll sound better but lose a little output vice versa with ported
the bl puts out alot of output but if you want that true kick in the ass and have the right power for it id suggest a btl
