Punkeyboozter
Members
    669
  • Days Won
    2
Everything posted by Punkeyboozter
  1. Punkeyboozter
    Volkswagen Lupo build log
    thats awesome bro, From what you say the sub obviously boogie but what is the SQ like for a non SQ driver? How did the two 6" aero's work for you at the end any noise coming from them?
  2. Punkeyboozter
    electrical problems big time
    Correct me if im wrong but he might just get close to 135 once the alt cant keep up and the batts start to assist. Still doubt he see that at the amp though. **edit stuped phone
  3. Punkeyboozter
    Sundow Neo 8s
    Where to buy them?
  4. Punkeyboozter
    Port area confusion.
    Thanks guys, a bit contridicting info here though. Wood already picked up. Maybe ill start a build log this weekend. The port will stick out a bit and it will be on the same face as the driver. Hope this does not cause cancelation or phase problems
  5. Punkeyboozter
    Does aero style ports still fall in the recommended 12-16 CBF range? Was thinking of a single 10" in a 6cbf loud daily tuned around 32-33 range or maybe 2x7" what do you guys think?
  6. Punkeyboozter
    Yes brp and thanks for the PM, I know the formula but the problem is how much is enough. Goal is loud daily aka loud but still sound good. Im starting to build the box this weekend Was thinking one port will be ideal and two would be fine for keeping it uniform, but I will try and avoid doing a whole bunch of smaller ports in order to keep it simple. Also by putting a bend in aero port will it affect the tuning bunch or is it too small to bother about?
  7. Punkeyboozter
    Hey Duran, Yeah sorry maybe i didnt word it right. Driver is a 18 N2 port is a 10" or maybe two 7" or whatever you recon is best. Not sure if I will be able to get these sizes either but I figured best to get the port area range right first Ive build many slot ports but only one or two low power earo style port boxes based on factory cut sheets so cant really make a educated decision. I've heard/read people say they need less but they never mention how much less.
  8. Punkeyboozter
    BTL questions
    -How many spiders are there in the N2? -Can we have super Gauss in the N2 or is it not required/superseded no longer relevant? What are the benefits and is it worth it? -AA SMD is designed by FI right...price and power handling aside which is a better driver for loud daily? Unfortunately I live on the other side of the world and have no way to listen to either of these. Thanks
  9. Punkeyboozter
    My Transaction with Mechman
    time to update the sig
  10. Punkeyboozter
    Wall Build for 2004 VW Jetta
    id start right with upgrading the shocks and coils first.
  11. Punkeyboozter
    I dont understand aero ports or whatever?..
    the answer to your question is application dependent. It is really that simple but make sure you get the placement and spacing right. Also make sure you have a tight seal around the port and it should not be able to bounce around. Port area required will be slightly less then a slot port but again its application dependent. Flares one both ends work better but it is not always done and results are mostly positive. might gain a DB or so as well as reduce port noise if this is done. Especially true with smaller radius's. It can be easier to to a slot port on really long ports unless you do external ports. hope this help some what
  12. Punkeyboozter
    Is bigger better?
    Depends on a few things but mostly power. Id do two in that size with rated power
  13. Punkeyboozter
    Is bigger better?
    I dont like high tuning. Some do..maybe build it long and then cut it down till u find the sweet spot. If u are not sure aim for 32-35
  14. Punkeyboozter
    BTL questions
    Urg my eng sux at this time in the morning
  15. Punkeyboozter
    BTL questions
    Na bro, was looking at them but decided to go with the n2 for weight savings, hope its the right choise as i cant try them around here. Been waiting for a while on the shipping price though. Might start working on the box 2morrow...send them a pic and ask whats wrong with the picture.
  16. Punkeyboozter
    BTL questions
    I was hoping they sound a bit different then the bl,s also hope its happy with double the power
  17. Punkeyboozter
    Is bigger better?
    off to the woodshop you go... You starting this weekend?
  18. Punkeyboozter
    Is bigger better?
    lol looks to me that option 2 will sound better build both and let us know.
  19. Punkeyboozter
    Time to upgrade
    Here you go Regular Price: $1,099.99 Special Price: $899.99 Add to Wishlist Add to Compare Quick Overview 4" ceramic coated coil Super-Gauss motor technology EMB flux linearization Dyna-cool system 7 spider pack Tri-Point suspension Hybrid foam surround Canti-Mount system Foamed core dustcap 32mm Xmax 3500W power handling Small ported applications Use code SMD for 100buck of of that. (not sure if its still valid) I was going to do that but my rice car wont be able to take the awesomness
  20. Punkeyboozter
    Is bigger better?
    I like the second one better to be honest, assuming your sub have enough clearance and the specs are correct and not taking the size into account. guess what im trying to say the design looks better not taking the numbers into account.
  21. Punkeyboozter
    Is bigger better?
    in that case it should be ok, however Id still rather turn it sideways or move it right to the end. Then again you might find that its the most awesome box ever the way it is.
  22. Punkeyboozter
    Is bigger better?
    depends on how long it is. Im no pro but I think if its close to the back of the box you might actually create a effect where the box might act like a smaller box. Well that and if you have to put a bend into it... If you dont have to bend the port turning it sideways might yield better results.
  23. Punkeyboozter
    Is bigger better?
    hard to tell to me honest but it sounds like it might just work. mind sharing why the port it where it is? Nothing wrong with tuning any higher either but you will lose some bottom end.
  24. Punkeyboozter
    Persuade me
    3 q's Actually im looking to upgrade from a 2 bl 12's to a N2 18 also running a 3000d
  25. Punkeyboozter
    Four BTL 15 N2s, three different cutouts
    Send him a shirt Mind sending me the quotation (from Singapore _) Thanks
