ManzKea
VIP Customer
    554
  • Days Won
    18
Everything posted by ManzKea
  1. ManzKea
    Hdc4 too close to the back wall.
    If you have the power I would go with xcon's. Why not the zcon?
  2. ManzKea
    Pro 6.5 and Super Tweet Question
    Soundqubed strikes again!
  3. ManzKea
    Sorry.... In my challenger I just have the Pro-Audio mids. And reguezelar Rockford tweeters. There was no where for those super tweeters
  4. ManzKea
    Why would it sound like crap? I have pro audio in my car. The Rockford one, but I do have the Rockford crossovers though. And in my other car I have pair of re audio components and the pro audio sounds crisper. But they do sound good in their ways, idk it is different between the two. But not in a bad way, more so a individual way
  5. ManzKea
    So it's finalized. I'm going with spl dean I'm so excited, I cannot wait till it comes in. I took my sub to a friend of mine to recone it, he I species my sub, gave it a few taps here and there and he concluded that my subs coil had shifted! That's why it's making those noises son certain notes. I'm super bummed out on the workmanship and/or QUALITY of my soundqubed sub. Maybe things happen for a reason, and this gave me the opportunity to see what spl dean is all about. I'm saddened by this experience, I really wanted to believe in soundqubed. The reviews, the pics, the unboxing videos, the pricing, all that. But I'm let down and will cut ties with this company and not suggest to anyone I can.
  6. ManzKea
    What's up guys and girls.
    What you got planned
  7. ManzKea
    If you have the power I would go with xcon's. Whats up man long time no talk. I have a taramps 5k 2ohm version. I want to really run a dual 12 set up but that's crazy expensive. So I might have to settle on a single 15. But a friend of mine is convincing me to try out spl dean and recone my hdc4. If the price is right I might go that route to try it out
  8. ManzKea
    Idk maybe. Maybe you seen me, I got a white challenger on black rims and also a white body kitted 03 altima
  9. ManzKea
    Makaha huh lol I'm in Maili. Ya definitely let's link up. I had my eye on the Xcon or even zcon but if you're saying the icon will persuade me, I gotta see it
  10. ManzKea
    I'm glad to see your guys concern and wanting to help! I wanna really bed be in the product. All the great reviews I've read online of the hdc3 and 4. And seeing how the 4 is the top of the line, I was expecting to be blown away!! Lol but idk whats going on. You say out side of the frequency, but my amps ssf is set quite high, at least in the 20's and my lpf, is set to the lowest hz, which is 50 on my amp. And that candy shop song is a typical normal hip hop song, no decaf no bass boosted note so I'm sure Amy run of the mill sub should play that song. You say I could send you guys the soft parts, what is that? The whole center piece, if that's the case I should just order a recone since I'll be having to re install it correct? And doesn't the aluminum voice coil handle more power(or was that heat)?
  11. ManzKea
    And ya i feel you on the shipping! Lol
  12. ManzKea
    Love my ICON, but shipping to HI was brutal. What up man. Where are you from? I'd love to hear an icon. All those reviews got me very curious
  13. ManzKea
    Do you think of recone it it'll fix it?
  14. Hey guys quick question. I got a dodge challenger and I upgraded my starter battery to a kinetik hc2400 and then I recently added a hc1800 as a secondary battery. I recently brought a dmm to mess with and check the Ohms of some subs I had lying around. Then decided to check my voltage . So both says it rests at 12.8 then I started my car and the main battery read 13.78 or so and I checked my secondary battery and it read 12.8 like nothing happened. This is the first time I've ever checked my secondary battery, I've had a dual battery set up in my altima. And I had the LCD volt reader and my secondary battery was in my spare tire area under my sub so I never really bothered. Is it suppose to jump up like the main battery? I brought the hc1800 off of Craig's list and the guy said he had it sitting on a tickle charger. I had it for about a month now so idk if this is normal or not. Thanks for any info guys
  15. Well idk where my wires go. Lol it just comes out this spot in the car, and it's like 8gauge or so. Plus id have to drill through the passenger fire wall and what not. It would be easier I believe to run it under the car. Tuck it somewhere out of direct exposure
  16. What kind of car do you have? And I know I know that's like one of the main parts of a big 3 but I was lazy
  17. I did not run a 0 gauge wire from the alt to the main battery. I just upgraded the ground wire, and the accessory power wire. Reason being, my main battery is in the trunk, and the alt is up front. I need to run the wire under the car, so I'll save that job for later
  18. Hm. Still lower than I expected. I guess the difference could be composed of difference in internal resistances. Just for clarification, with the batteries hooked in parallel both will be feeding your amplifier. I guess so. I'm not too certain. It's wired in parallel, and my amp power and negative wires go directly to the secondary battery. No isolators to separate the two batteries. Just a fuse on the positive wire between the two batteries
  19. Thanks so much guys. It actually was the fuse! I guess I overlooked it because I have those with the led lights that suppose to light up when blown. I swapped it and sure enough second battery shot up to 13.08 a little less than the main battery but I'll take it. Especially with my taramps 5k
  20. Alright guys thanks for the suggestions. I will look into the fuse. I am not using am isolated. Just running it in parallel. Wouldn't the battery slowly drain if its not connected to the main battery. I've had it in my car for a month or so
  21. No distribution blog k. Just positive to positive negative to negative. With a fuse between the two. 0 gauge wire. And I connect my sub and 4channel amps direct to the battery
  22. Alright that sounds like a great suggestion. I'll try that tomorrow . All connections should be good. They are litteraly less than 20" away. What also became a concern is what my amps are seeing volt wise. Since its coming off the secondary battery, does that mean this whole time my amps have been seeing 12.8 volts? Lol
  23. That's what a I was thinking! And I have it wired in parallel . So I should switch the thing. If that's the case I can get a good deal on an optima but I know it's frowned upon to mix batteries
