![](http://www.soundsolutionsaudio.com/forum/uploads/set_resources_8/84c1e40ea0e759e3f1505eb1788ddf3c_pattern.png)
![](https://secure.gravatar.com/avatar/db7f14d5dfafb81f712e0d4451f5a6b9?d=http://www.soundsolutionsaudio.com/forum/uploads/monthly_2017_07/D.png.02ca383754aa62209665492a5d322f39.png)
Dragon76
13 -
Posts posted by Dragon76
Thanks for sharing.
0 -
Ok sounds good thanks a lot
0 -
Ok also when it comes to the raw drivers are there anything I should look for as fare as what material they use to make them?
0 -
Ok I mean what model should I use for a active 3way raw driver set up for my front stage. Also when u said scrap the rears do u mean I should run a midbass instead and how big would 6" be too small or should I go with a 8"
0 -
Thanks
0 -
So I want to run a active set up for my fronts and rear my question is what unit minidsp do I want to use a 6 or 8 channel and also what model number that would be any help would be great as I'm new to this kind of set up.
0 -
Thank you
0 -
Hey Shannon thanks again for the info I will definitely have to make a trip there to check out your set ups take care my friend.
0 -
Cool thanks for the advice.
0 -
Ya I'm going to try my first active set up for my front and rear stage checking out what parts express has to offer going to run a DSP not sure what brand a friend of mine told me to check out a company called minidsp or maybe Zapco or Helix.
0 -
Ok thanks
0 -
Looking to run a Sound Quality system just wondering when it comes to SQ is sealed better thing ported I here if you run sealed you need more power to push the subs.
0
Zapco Amps with DSP
in Newbie Sign IN
Just wondering has anyone used the Zapco amps with built in DSP. I was informed that they are the same ones minidsp uses and could I use these for an active set up?
