Julian
Super Moderators
    7,743
  • Days Won
    32
Everything posted by Julian
  1. There is a posibility santa will be bringing me an Eastwood plasma cutter. So i'll use that for the brackets.
  2. Julian
    Welcome to the IHoP v.2
    Which 70-200?
  3. Show us because Stetsom has never showed us one that i recall.Even Usina Spark doesn't make any yet and they are the largest provider of Fonte's in Brazil. I've been in talks with LiFePO4 companies and Hlabs about 12v Boost converters since only the LiFePO4 community and Hydraulic community are only 2 that use them the most in vehicles. Actually it's soundigital Doesn't matter, all Brazilian
  4. Yeah same here Thanks guys, Ryan took in my wants and needs and this came out.Need to get the lumbar for this now
  5. I know Stetson sells a 12v to 300vdc inverter that looks like a small amplifier that allows you to charge the bank from your stock 12v system.
  6. Instead of buying a new alt for the dual alt setup I'll be using the old alt out of the mustang, going to convert it to self exciting and fabricate a bracket, whenever I get the money I'll replace the factory alt with a new mechman. I need to figure out how I'm going to cut .25" steel, lol.
  7. Honestly I would do it. Or you could space willing flip the battery on its side to get an even larger battery. With a bit of fabrication you can fit huge batteries in most cars. I think mine came with a group 34 upfront and I was able to make a battery tray out of aluminum and fit a huge group 31. Just comes down to your level of fabrication skills and level of comfort possibly "massaging" a larger battery in.
  8. The box is going to be 15.5ft^3 tuned to 30hz for the rear chamber, and 24.5ft^3 tuned to 50hz for the front chamber. The entire box is double layered with the sub baffle quadruple layered and front of box triple layered. The overall dimensions are 37.75" wide x 35" tall x 72.25" deep. Everything but the front is going to be sandwiched between the top and bottom pieces, so naturally everything between them will be 32" tall.
  9. Thats ea in general here is a cheap hdd from ebay http://www.ebay.com/itm/New-120GB-HDD-Internal-Hard-Drive-Disk-Kit-for-Xbox-360-Slim-Console-Game-HS/111527512027?_trksid=p2054897.c100204.m3164&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140407115239%26meid%3D280b7625bb8245c0aa2371fa4be65151%26pid%3D100204%26prg%3D20140407115239%26rk%3D1%26rkt%3D30%26sd%3D221610210052
  10. Gonna heat shrink them when I solder the leads.
  11. Burnt the carpet.. A little bit...
  12. I wish I could afford that lol. I just talked to Ryan from ram designs and we planned out an excellent play all demo design that is a 6th order.
  13. i plan on using the stock back seat mounts to attach the wall securely to the car, I'll be welding a frame together with risers that will attache to the four seat mounts and i will make it even with the rear. I'll be wasting some space but i'll gain more access to the rear fuse box and some extra storage below the wall for random stuff. at this point I'll have to make a cut out of the inside of the wall for an access so I can access the fuse box from above.
  14. I have access to a pallet of deka intimidators and alliance batteries here in Kansas City. Price is 65 each picked up, shipping may be possible BUT a large qty would have to be bought. Sometime next week I will know the total qty of good batteries, they are used or b-stock.
  15. Julian
    2005 tahoe road to 150+ db
    Power is power man
  16. Julian
    Taramps hd 8000
    Wow already?
  17. Used is relative, the batteries have only been used in vehicle for 4 months and they offer a 3 year no questions asked warranty. The pc1800s are incredibly strong batteries, in my testing they are just as strong as four diehard platinums. Plus the overall depth of the batteries is very shallow which is good for a behind the seat box. Pound for pound the best batteries for the application imo
  18. Unfortunately life has been chaotic lately. The plan is four zcon 15s in a 6th Order band pass on two taramps 8k.
  19. Julian
    They are incredibly loud since they aren't pwm so they are on constantly full throttle. You might be able to find some higher quality fans which would be able to quiet it down some.
  20. Live mode* Download ubuntu Load image onto a flash drive or disc Boot from storage device Run live mode Download Windows 7 Burn to disc Boot from disc Install from disc. Use key on bottom of laptop to verify copy Doneskies
  21. You can run ubuntu in love mode for free then download a copy of Windows and then boot to that and install it
