ludeman
Members
    335
  • Days Won
    11
Everything posted by ludeman
  1. ludeman
    '12 Grand Cherokee
    Bad Radio! Got a same model open box from Best Buy!
  2. ludeman
    '12 Grand Cherokee
    The radio ground was checked first, grounded to metal. Only change was the Northstar agm's. No noise if I power the speakers off the radio. Only when I use any rca output.
  3. ludeman
    '12 Grand Cherokee
    TDH show is a no go as of now! I got radio noise in the speakers, I can hear the fan from the radio and a thump when it turns off all while the volume is at 0. No engine noise or alternator whine? Pulled the radio out switched rca's ran it on top of the interior and the same noise is there, ordered a ground loop isolator last night. Gonna try grounding the radio rca inputs in a few. Grounding the rca made it worst!
  4. ludeman
    '12 Grand Cherokee
    I'll be there on Sunday
  5. ludeman
    '12 Grand Cherokee
    Your SSA STORE Order Confirmation (#1X553)!
  6. ludeman
    '12 Grand Cherokee
    Another option if I get the Limitless 40ah lithium it will fit in OEM battery location!
  7. ludeman
    '12 Grand Cherokee
    My choices: 1. 1 XS Power SB1000 2. 1 Limitless 20ah Lithium and 1 NSB 94r 3. 1 XS Power SB500 and 1 NSB 94r Let me hear some feed back!!! I'm stuck on choices. The cheapest is #3 most expensive is #2!
  8. I say start here: http://maestro.idatalink.com I did: http://www.soundsolutionsaudio.com/forum/topic/72654-12-grand-cherokee/
  9. ludeman
    (2) Fi BTL 15" - 15000 watts in the trunk
    How are you liking those Superbanks?
  10. ludeman
    '12 Grand Cherokee
    Might have room for SuperCaps gotta measure this!
  11. ludeman
    '12 Grand Cherokee
    Update: Was getting low voltage readings, resting at 12.0 car running is 13.9 - 14.2! Pulled out batteries and my XS power's are done after 7 years of hard work, the D3400 was resting at 9.5, on the charger (4 times) it went in to desulfation mode for a few hours then read Bad Battery! The D3100 charges normal goes to 100% then drops to 70% over night! Now the resting voltage is 12.5, running is 14.5 - 14.3! Now I'm debating on which batteries to get. As for stock location there is no real impressive replacement, 1 might have a higher Ah but lacks in reserve or another category, but none is higher in all categories compared to factory agm. On to the battery bank, I like the Limitless Lithiums.
  12. ludeman
    Aero port idea
    I'm playing around with designing a single 18" box, 5.5 c/f max for a single 8" aero or 6.3c/f with 2 6" aeros is what I came up with at 9" per c/f, the lowest I'll go with when using an aero port. Do you have the SPL surround & come?
  13. ludeman
    Welcome to the IHoP v.2
    While browsing Ebay: http://m.ebay.com/itm/282385760107?_mwBanner=1
  14. ludeman
    SSA Evil 1 (first SSA tweeter)
    PayPal ready!
  15. ludeman
    '12 Grand Cherokee
    Patiently waiting for the Evil 1's and good weather.
  16. ludeman
    '12 Grand Cherokee
    Evil 6.5 with 6x9 pvc adapters'.
  17. ludeman
    '12 Grand Cherokee
    While on lunch: SSA STORE - Order #18706!
  18. ludeman
    '12 Grand Cherokee
    Another shot of the gauges:
  19. ludeman
    '12 Grand Cherokee
    Didn't realize how heavy the subs were until I had to lift them up to put them in the box!!
  20. ludeman
    '12 Grand Cherokee
    Update: Box #2 is finished, loaded and playing with the Zv.4 12's! Pictures tomorrow
  21. ludeman
    '12 Grand Cherokee
    This kinda puts a priority on things!
  22. ludeman
    '12 Grand Cherokee
    Here is the link to check what's compatible: http://maestro.idatalink.com/
  23. ludeman
    '12 Grand Cherokee
    Box #2 taking form, much like box 1 but 4.5 c/f tuned to 35hz with port on drivers side for 2 Zv.4 12's. Just going to be raw finish for BassRace testing.
  24. ludeman
    '12 Grand Cherokee
    Sooner than you think! Just ordered some 6x9 PVC adapters for the front doors to fit the Evil 6.5, the tweeter pods are 2.2", the McLarens are 2.27" & Evil 1's are 2.44"! .24" is not that much of a difference, going to run active by my Cactus 250.4.
