Hell-Razor
Members
    472
Everything posted by Hell-Razor
  1. Hell-Razor
    Just ran into a box problem...
    What about subs forward or up and ports back?
  2. Hell-Razor
    What subs would be best?
    I have some other questions that Ill throw in here seeing as ///M5 doesn't like me starting new topics for well, new topics. Is there an easy way to find out how much wire you need for wiring two batteries together (I think its pos to pos, neg to neg)? zero gauge wire isn't very cheap and I am going to need (I would think) about 20-25 feet of it to do my big 3, and wiring for my batteries. I could just run a string from my back to the front inside the car I guess then measure that. May be more hassle though then needed. What do you guys recommend for a heat source to solder the wiring to the terminal ring to the wire itself? Or is there a terminal ring that doesn't need to be soldered? I was told that its very hard to solder anything thicker than a 4 gauge because you pretty much have to melt the wire before you can solder anything and be efficient (may be wrong though). I have one of the Craftsman Soldering Guns but not sure if it has enough umph to solder 0 gauge. Going at where I think I am going to go, I would most likely get the 12" BTL's unless there's something I see within the next week or so that says no for me. What would you guys recommend for an amp to power both them? What is the average shop cost for installing an alternator for you guys? I am not 200% sure how to install an alt and I have been looking around for people to either install it for me or help me install it. There is what I think the intake manifold over the top of the alt and it looks pretty tough to take that thing off. For wiring circumstances, should I run the power wire opposite sides than everything else? I remember reading some wires will give out "noise" to others and you will hear buzzing sometimes from stepping on the accelerator or engine noise... Is 12gauge wiring good enough for front end speakers? I will be throwing about 150 watts tops at them
  3. Hell-Razor
    Also just though of some more ideas -- I want it to hit hard, be in a ported box (prefer that sound over a sealed), good excursion for SPL...ill keep on posting the more ideas I get.
  4. Hell-Razor
    Alright seeing as I haven't been very clear I guess here are my goals: To get a woofer that sounds good. To be able to hit the lows at high volume without distortion (i know it will happen eventually with every sub). To be able to upgrade later (ie amp if I under power or if they will accept more power). To be able to compete and put up good numbers for the woofers I will have. This is playing music, not one tone. To be able to play most kinds of music well. To get the max potential out of the woofer. Ive heard some systems where all you could listen to on it was rap, I do not want one of those (it may just be the car as well or the build). To fit the woofer(s) in the trunk and still have room to spare. Nothing too expensive (over my 3500$ budget that is). Have a woofer that can pretty much do what others cant in volume, bass and spl (and quality). There were people saying to me I cannot build a good system on my budget, I want to prove them wrong and destroy their stupid little JL's pushing 1k watts (a guy that owns a company here was saying that there's no way these speakers can do what they show on youtube for example. That its fake and people just re coned them with a 1000$+ driver) And pretty much to get the best bang for my buck. Oh and I don't want to be disappointed. I don't know what else I may be looking for. I hope that's good enough for you guys to help me narrow down my choices. If not, ask me questions cause right now I am a little on the sick side and my mind isn't working very well...
  5. Hell-Razor
    Ported Box for 2 12''Fi BTLs
    PM Shizzz. He will help you out but super busy at the moment. I am still in line for being helped through him.
  6. Hell-Razor
    lol you guys are...well this will way enough Anyway. Still trying to figure out either a BTL or BL. BL can handle a lot but BTL may be over the top in loudness compared to the BL...
  7. Hell-Razor
    NIB? I think I am pretty sure I am going with either the BL or BTL at this point. Excellent reviews, great power handling and within my budget.
  8. Hell-Razor
    From what I have seen about these subs, I think I will pass on buying one from a very iffy company...
  9. Hell-Razor
    ant isn't there a reason why you see most people frying their funky pup woofers(setting them on fire)? i think there's better out there for the power you push (that just my thoughts nothing to back it up though)
  10. Hell-Razor
    You said I cant do that and have the car look stock....
  11. Hell-Razor
    funky pups.... why?
  12. Hell-Razor
    Oh you mean the option with the sub. I thought you meant the bp was with the amp =P. Thanks Old Skool and jay. LEts see what Shizz things about this idea now.
  13. Hell-Razor
    Ok for a 2 12" design what would be best for building the box? I was thinking of firing them up and forwards towards the driver at a 45 degree angle about. With a square port directly between and behing the two subs... But I heard that if the subs fire directly up towards the top of the trunk with a port on the bottom towards the back of the box is the best...
  14. Hell-Razor
    what do you mean by "bp power"? And tossing 1750 at each is...pushing it as they are only rated for 1k. But I wouldn't mind doing it....
  15. Hell-Razor
    Also, 1x SAX-1500D for 1x BL right?
  16. Hell-Razor
    Alright that makes sense. I am going to wait though until I order anything sub wise to talk to Shizzz again. He is one busy guy and I have a feeling he will agree with you. Well, powermaster D3100 battery here I come!
  17. Hell-Razor
    If I decide to push 2 12" BTL's, what do you guys recommend amp wise? (I am going to most likely get them). How about BL's if I try to save some money?
  18. Hell-Razor
    sundown sax 50.4
    I feel a little out of place posting here but with Brooklyny's post I don't feel so far off topic anymore. I just received my amp and realized that holey hell there are a lot of nobs on it. I don't know what most of them do. But going through my booklet (made great bathroom reading material ) I notided I had a LOT of questions, not only "what does this nob do" but "why would I need this"? Anyway some of my questions are: What is the Variable High and Low pass filters and how should I set them? (If I remember correctly the low is the lower frequency's and the high are the higher ones. So I would want to cut out anything that I want my sub to play?) Should I leave the bass boost off? (I am pretty sure I read that they should never be set on the amp or the deck). I assume the knob is for this. Theres a 12dB Octave Electronic Crossover Slope....huh? Theres also a 12dB Octave Variable Subsonic Crossover Slope...I say again, huh? With al lthe fun looking, I want to play with, knobs. Are they set to anything before shipped?
  19. Hell-Razor
    SAX-50.4 and Z15 Close-Out Sales
    SAX-50.4 RECEIVE!!!
  20. Hell-Razor
    My budget is about 3500$, cheaper the better though. I have already ordered my front end speakers, my front end amp and wiring for it. I think it was about 475 so far. I figured out with the 0 gauge wiring, 2x AQ2200Ds, 2 12 Fi BTLs, my head unit, the battery and the alternator come out to about 3300. I could save money though and go to the BL's but then I don't have head room for a bigger amp to power both of them. And I think its harder comp wise if you have 2 amps cause then you are in a harder category.
  21. Hell-Razor
    Shizzz -- I am getting a new alt as well. Some guy on these forums is hooking me up with a 200 amper. Seeing as now I can handle more power, would you change your original idea of 4 10's or 2 12's?
  22. Hell-Razor
    /me shrugs.
  23. Hell-Razor
    alright well... Lets do 2 12's then. How about BTL's like my first 12's choice and get them powered up. For the first few months I will have them underpowered but towards the end of the year I will be able to strap another amp on there. Oh and by the way, I am getting a 200 amp alt sometime soon. Im thinknig of ordering a 2200D because a 12 BTL should be able to hold 2.2kw a peice. I think if I went for a SAZ-3500 I would a)out to my alt by the time I strap in a second one and b) go a little over my budget. But I guess with a battery bank I may be able to strap two 3500's but thats down the road... Or maybe even sell the 3500 and get a 4500.... But I am getting ahead of myself here. The BTL requires more power at the start but can handle more power than the BL overall (I think at least). If I am trying to get the best I can (and I am) and want to upgrade more later (I do), wouldnt the 12" BTL be my best bet? NOTE: I am only talking about the BL and BTL because I have read a LOT on them and dont know much about the other options outside of Fi.
