hdrox88
Members
    730
  • Days Won
    11
Everything posted by hdrox88
  1. Sent ya an e-mail, not sure if you got it though, I am sure you are busy so no prob if you haven't gotten to it.
  2. hdrox88
    subs in sealed
    How much power do you have on tap? Just check out Fi's website. They have a description for all of their subs.
  3. hdrox88
    2 12s or 1 15?
    2 12s have more cone area so there is potential to be louder if the install is right.
  4. hdrox88
    ZED Audio amplifier group buy
    I tried to look at the manual above and it said I don't have permission to view the attachment. Why is that? I just updated permissions, try it now. Works for me now. Thanks.
  5. hdrox88
  6. hdrox88
    H/O Alt or Not?
    If it was me, I would get the HO alt and a couple good batteries. You could always install the amps and monitor voltage very closely while playing and go from there. Just don't let it dip too low.
  7. hdrox88
    help!!! DC vs AA
    Better for what? What are your goals?
  8. hdrox88
    How bad is your hearing loss?
    Haha, me too every once in a while. It seems to be the older ones the most.
  9. hdrox88
    FeedBack **Positive**
    crazytexan: fast payment easy to work with Thanks
  10. hdrox88
    Quick Question
    my gain was probably 1/8 of the way turned up. is that ok? You should set it with a DMM or Oscope if you can. But 1/8 seems a tad on the low side unless you have a line driver.
  11. hdrox88
    Quick Question
    I agree, and make sure everything is adjusted flat or to 0 when setting gains.
  12. hdrox88
    Quick Question
    If your pioneer is anything like mine the bass boost ups the bass to the sub and the speakers. Sublevel control is just the sub. A bass knob for an amp can vary from amp to amp.
  13. hdrox88
    the loud button on head unit
    The loud function boosts the high and low frequencies. It is useful for low volume listening to help it sound a little better. It should be off when setting gains. If you set with the loud off, dont use it a high volume or you will more than likely start clipping.
  14. hdrox88
    how to add picture in message
    I upload photos to photobucket. Then you find the image you want to post and copy the image code from photobucket and paste it in your post on here. No insert image is needed.
  15. hdrox88
    Sub examples pls?
    Hip hop or drum and pass wasn't meant to overpower everything. Agreed. In a true SQ setup everything should be well balanced.
  16. hdrox88
    Sub examples pls?
    I think, in your case, you're using a definition of SQ that the OP isn't. I think it's safe to assume this is more "keeps up with most music and sounds good but can still whang," not the OCD staging and designing that SQ fanatics think of. After all, SQ just stands for "sound quality", and you can want that in a setup that also gets mega loud. True, but....Check number 15 click
  17. hdrox88
    need some advice
    so what is the airspace for the 18s, and the airspace for the 15s, and i guess tomorrow i can measure what i can give up and go from there. I am not familiar with nightshades so someone else will have to help ya on that one.
  18. hdrox88
    need some advice
    If you have enough space for the 18s to be in the right enclosure then do that. If you only have enough airspace for the 15s then go that route. If you choke down the 18s in too little air space the 15s in the correct airspace have the ability to sound better and louder. It depends on the install. More cone area has the potential to get louder in the right install.
  19. hdrox88
    need some advice
    i know what your saying bout cone area So what exactly is your question? Are you trying to decide between 15s or 18s?
  20. hdrox88
    need some advice
    Yeah, cops AND crooks. Gotta bump respectively sometimes.
  21. hdrox88
    need some advice
    Well, an 18 has more cone area than a 15 so if you want more cone area 4-18">4-15" Not sure if that is what your question is. Not to be a jerk, but, punctuation helps us understand what you mean.
  22. hdrox88
    DC Lvl 5 10 Testing for Limits
    Thorshammer...I was just reading your sig and couldn't help myself. How is that 220 amp alt working for ya in the trunk? LOL
  23. hdrox88
    Box design
    Well apparently WinISD isn't accurate so that kinda sucks. But if you end up wanting a different box I can design one with a 3D shot and cut sizes.
  24. hdrox88
    Box design
    Is there a program that can accurately display response? Or is using some tones and a meter the only was to map the frequency response?
  25. hdrox88
    Box design
    If you get a box extremely large like 18ft^3 than it will be like playing the sub in free air. The larger you go in box size raises the ease of bottoming out. But don't let that fool you, you can still bottom a sub in a tiny enclosure.
