I will spend the next several days catching up this build log. I will be sure to cover the truck's history and how this became my new project. Figured I would start with a pic of it as the first time I had seen it in 2012. I have a few pics I have snatched up of it in it's earlier stages that I will share as well.
All I can tell ya...is this poor thing is just a ugly beast.
  • Replies 82
  • Views 16k
  • Yes this is correct genius...And quit neggin all my post your just making yourself look like a little bitch!!
  • jcarter1885
    jcarter1885
    Yes you usually change the thickness of the loading wall, height of the port or width of port just like any other enclosure to adjust the tuning.
  • Uhh yea..Every time he logs on i get but rapped..lol..Guess you must be hitting him from the behind
LOL, ugly is a fitting description.
Looking forward to seeing what goes forth with it!
Tuned in CHOP!
Both sides....well....had thier own unique attributes lets say.
IMG_288084733042436_zpsppuf12ex.jpegURL=http://s151.photobucket.com/user/porkchop22_2007/media/Mobile%20Uploads/2014-06/IMG_50318654815932_zpsfvnqzccc.jpeg.html]IMG_50318654815932_zpsfvnqzccc.jpeg
The roof ....oh my lord the roof..the external speakers. ...covering so much more wrong under them..all the screws , brad nails, and dents. ..mixed with bondo, bed liner, silicon, resin....you name it....
I did not initiate the tear off....I probably would have chosen similarly. ...but I can bet we both agree. ..leaving them alone would of seemed a better choice.
lots of work to get it....well...to just a state of okay at best.
You have the good dash for spl. No map pocket under dash.
I have the alternator and regulator off that truck.
Trouble is coming !!
Looking forward to the progress.  I love rescue builds.
So I did miss something how many watts do you plan on running....just wondering
Steve, this exact truck?
That would be too cool if so.
I am currently trying to look at some alternator options.
Trying to build what I can to keep the budget low for a bit longer.
These two singer 275a came from Acousta.
Sort of small power and they have the wrong pulleys.
So for now..I am just toying with the ideal of doing this route.
My original goal was something sort of high...20k+
I guess budget and opportunity will be the deciding factors. Time is on my side for now. ..no rush for a while.
you're gonna keep saying that until 4 weeks before slam !!!!! get on it !
pretty sure. Got from H.V.
Yup...that would be the same one then!
Too cool
This is the roof after cutting all the screws and brad nails flush.....sanded all the resin, bondo, bed liner, & silicon off primed it......since this.....we have used body filler to fill the holes and partially most of the dents.
For some of you...here is the first look into the cabin. .this is the port mouth.
Yes....the walls are rough.
And yes....the debris is from a brick of fireworks.
(Kids will be kids) lol
What numbers has this truck seen in its history?
This will be interesting
