Posted March 30, 200916 yr This one is 3 cubes @ 35 hz for a trio of DD 1508's I believe. Used a pair of 4" precision ports and had to put an elbow on each. Box will be left bare and have all edges rounded over.
March 30, 200916 yr When you measure the distance of a aero port that is curved, do you take the inner side, the outer side, or an imaginary line in the middle?
March 30, 200916 yr Author When you measure the distance of a aero port that is curved, do you take the inner side, the outer side, or an imaginary line in the middle?Down the center. In this case, the center length of the elbows was 10" IIRC.
March 30, 200916 yr Author Very nice, I loved my 1508's. can you get a pic of the elbows?If I remember Ill get some pics next time I use them. But, they are just standard 4" 90* PVC elbows.
March 30, 200916 yr Amazing work! I love the look of the unfinished box. Alot of sanding to get it to look like that?
March 30, 200916 yr Amazing work! I love the look of the unfinished box. Alot of sanding to get it to look like that?actually trupan has a better look to it over mdf when both are non-finished so more the wood itself over sanding leaves that type of finish but with exterior edges routed , woofers counter sunk, and trupan as the material , it comes out looking so nice no need to cover IMO
March 30, 200916 yr Author Amazing work! I love the look of the unfinished box. Alot of sanding to get it to look like that?Nope, not much sanding at all actually.
March 30, 200916 yr Very nice, I loved my 1508's. can you get a pic of the elbows?go to home depot pvc plumbing isle 4" 90 degree elbow you can source them there Edited March 30, 200916 yr by 350zspl
March 30, 200916 yr When you make your initial cuts out of the sheet, do you use a table saw or a circular saw?
March 30, 200916 yr Author When you make your initial cuts out of the sheet, do you use a table saw or a circular saw?Table saw all the way. Much better than a circ saw.
March 31, 200916 yr Where do you get Trupan at? Is it available at a local lumberyard, Lowes, Home Depot or Menards? Edited March 31, 200916 yr by OldSkool_08
March 31, 200916 yr Where do you get Trupan at? Is it available at a local lumberyard, Lowes, Home Depot or Menards?not sure exactely were he is buying that wood at, but hes been using it for years Edited March 31, 200916 yr by 350zspl
April 23, 200916 yr saw it at home depot for $49 a sheet i believe.let me know when you are ready to drop a saz 3k in your rami got a mint one for the low low $
June 12, 200916 yr judging by your username, is that going in a 350z?!?! i didnt know the trunks were that big. very nice looking box btw.
July 21, 200916 yr judging by your username, is that going in a 350z?!?! i didnt know the trunks were that big. very nice looking box btw.thanksmax exterior dimensions in a 350z32x15x19
