Posted February 23, 200620 yr I should be receiving my 12" RL-P tomorrow sometime and would like to try and get the box built for it this weekend. I've read more times than I can count that the RL-P loves to be ported, so that is definately the type of box I am leaning towards. And I want to try donwfiring since it will be in an extended cab truck.I should start by saying I have very limited dimensions but can still get the required space.The dimensions I can use are, no more than 26" high, 21" across, and 14" deep up to about 14" high and 10" deep from there up. Kinda hard to visualize? shape would kinda resemble a chair.My questions are as follows:With downfiring would the port direction matter? I can do to the passenger side, forward or up (up being the hardest to get the right length)By SS website 1.5 cuft with 20 sq in of port is what I should shoot for, but would I be better off with 21.25 sq in of port or closer to 30 sq in? Those are pretty much my two options as far as port area go due to the limitations of my truck.Would a tuning frequency of 32Hz be okay or are there better suggestions? (music taste is just about everything)Thats the only questions I can think of right now, I'll post anymore that may come to mind.
February 23, 200620 yr I'll let someone with experience working with trucks answer your question about port firing... but as for your other Q's: I would opt for the ~21 square inch port area. You could go to 30 if you really want to, but it's unecessary and will only serve to require a longer port overall. As for tuning, 32 Hz is a good level for what has been dubbed the "SQL" style setup. In the car audio environment, I would opt for anything between 28 - 34 Hz. Lean lower if you want more emphasis on the low-end, and lean higher if you want more overall output. I'll also note that if you go with a lower tuning, you can raise your net volume up to 2.0 cu ft in order to boost the output while maintaining a reasonably flat response curve. As you go towards higher tuning frequencies, I would keep the box down closer to the 1.5 cu ft net measure, as larger boxes with relatively higher tunings can create some undesireable peaks in your response.
February 23, 200620 yr All truck cabs are a little different and prone to sweet spots. What make and model is it? Someone might have tried in one...
February 23, 200620 yr Author Thanks for the quick reply and all the helpful info there. After playing around with more numbers I can get the net volume between 1.8-1.9 after displacements and a 30Hz tuning.If there is a way to increase low end at 32Hz and 1.5 cuft please let me know, as I could possibly go that route. Hopefully tomorrow I will have sometime and I can see if I can squeeze anymore room outta the space I have. The truck is a Nissan frontier king cab (extended cab) Edited February 23, 200620 yr by Jester1318
February 24, 200620 yr Author Sub came in today and it looks great. I had no idea these were so heavy. I put it in a 1 cuft box just to get a listen and it sounds okay in that. (didn't get to do much listening)Does anyone have any suggestions on the port firing direction?
